Your computer problem is caused by a missing sound driver. You have to reinstall your computer drivers by it's driver installation cd. if you don't have it or your computer or soundcard driver installation disk is missing. then do this.
Try to find out your motherboard or soundcard manufacturer. You can download the driver that your motherboards or soundcard needs . But if it is too expensive there, try to use driver magician , after installing, driver magician will automatically detect your computers missing or outdated drivers. All you have to do is to Click the all detected driver that driver magician has detected from your motherboard, it will automatically search the internet and download the driver that you have selected. Press save, then install. There you have it. Have a nice day.
Testimonial: "nice... thanks po i'm start to re install my audio a couple of minutes ago and its work really really work thanks again ti all of you :)"
Hello
You have to reinstall the audio driver of your desktop computer.
Hi udelie_dali,
Welcome to FixYa! How are you?
It looks like you have not installed the audio driver after you reformatted your desktop computer.
Please install the audio driver. You can find it on the cd that came with your computer or you can download it from the computer manufacturer's website (example: support.dell.com).
Hope that helps. Please let me know if you have questions. Thank you for using FixYa!
What
I could recon from your question is that your audio driver is not
installed in your reformatted PC.
Please
be informed that any Driver software depends upon the PC make, Motherboard type
and Operating System. You need to know all the three information's to do get
going.
Please find the Driver software's of your Audio and video inside the
installation disk provided with the PC at the time of purchase. As you have not
mentioned your PC make I am unable to give you the direct download link. However
you can download the same by visiting the website of the company that
manufactured the PC.
Even
here you need to be careful to download the correct software for your PC. You
need to be exact with the PC make and Model number and the OS that you are
using.
To install just Double clock on the driver setup.exe file and go on clicking 'Next' until you get the 'Finish' option and restart the PC.
What I
could recon from your question is that your audio driver is not installed
Please be
going.
Even here
you need to be careful to download the correct software for your PC. You need
to be exact with the PC make and Model number and the OS that you are using.
To install
If you feel that my answers have helped you getting
solution to your problems then please give a vote.
Thanks.
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
What I
Please be
going.
Even here
To install
