Question about LG External DVD Burner USB 2.0 GSA-4120B SuperMulti Dual Layer DVD±R + CD-RW Burner w/ Heavy Duty Al... (D4120FK51UBKA25DVDR4X) Burner
I just bought a USB External/GE24 Super Multi Rewriter, with 24x speed. my problem is, when it burns, it burns EXTREMELY slow. I used to have an 8x burner, that would burn in about 5 minutes, and this one had taken 2 hours, and only had burned 14 percent. Any ideas???
Posted by mklvon on
Joel Mariano Gonzales
    Scholar:
    New Friend:
  • 34 Answers
Hello mklvon,
Welcome to FixYa.Com!
I would like to recommend that you first take a look at your computer. Check if you have a USB 2.0 High Speed port. Reason is because although you have a USB 2.0 Ext Multi-Burner but your connecting it to a USB 1.0 or USB 1.1 port, the Multi-Burner will only run as fast as the USB port can transfer data.
Another time I would like to recommend is for you to take a look at the USB cable itself. As it is an Ext. Multi-Burner it may require a power USB port w/c is the reason why most Ext. Burner's have a Y-connector that is one USB port on one side and the other side branches off to 2 USB ports as it required extra power. If it is, you may want to consider your options as to getting a powered USB port.
And lastly, I would recommend that you take a look at the type of discs you are burning on to. Not all DVD R are the same. Whilst some have 24x speed some can have 4x speeds which can also affect the burn speeds.
Regards,
Deathschythe33
Posted on Aug 22, 2011
How can i get the specs for hl-dt-st dvdram gt20n
It's an ATA device. (ATA / IDE)
At MAXIMUM:
A) It can play back DVD's at 8X speed,
B) Read CD's at 24X speed,
AND Write,
1) CD-R's at 24X speed.
2) CD-R/W's at 4X speed.
3) US CD-R/W at 24X speed.
4) High Speed CD-R/W at 10X speed.
5) DVD-R at 8X speed.
6) DVD-R/W at 6X speed.
7) DVD-R+ at 8X speed.
8) DVD-R Double Layer at 6X speed.
9) DVD-R/W+ at 8X speed.
The optical drive in a Toshiba Satellite L455D-S5976 Notebook PC, is a DVD Super-Multi drive, that is capable of using disks that are Double Layer, and R- or R+
In all actuality about what is the best burning speed, it is the Slowest speed that you can choose.
That is usually 4X.
However I would recommend 8X in all situations.
Makes a better burn, and is easily readable by other optical drives.
Makes it simple, huh?
For additional questions please post in a Comment.
Regards,
joecoolvette
Jan 10, 2012 | Toshiba Satellite L455DS5976
Vista driver
http://www.lgsolutions.com/products/digital-storage/optical-disc-drives/dvd-drives-external/gp08nu6b-super-multi-portable-slim-dvd-rewriter#literature-and-downloads
Vista and Windows 7 automatically find the drivers by the way. Just get to the Device Manager, locate it in the list under optical devices and right click on it and choose update driver.
Dec 19, 2011 | LG GP08NU6B DVDWriter Black External...
Can't watch blue ray movies on my acer aspire model 5334
Taken from the acer support website.
" Optical media drive 8X DVD-Super Multi double-layer drive:
  • Read: 24X CD-ROM, 24X CD-R, 24X CD-RW, 8X DVD-ROM, 8X DVD-R, 8X DVD+R, 6X DVD-ROM DL (double-layer), 6X DVD-R DL (double-layer), 6X DVD+R DL (double-layer), 6X DVD-RW, 6X DVD+RW, 5X DVD-RAM
  • Write: 24X CD-R, 16X CD-RW, 8X DVD-R, 8X DVD+R, 4X DVD-R DL (double-layer), 4X DVD+R DL (double-layer), 6X DVD-RW, 8X DVD+RW, 5X DVD-RAM
This model of computer does not have a blu-ray drive unless you got a third party upgrade. In this case, you will need to track down special drivers, which can best be done by whomever sold you the drive.
Jun 10, 2011 | Acer Aspire One PC Notebook
Sir i am using acer 4736z i got problem with my dvd driver when i am inserting blank dvd for writing operation it shwos 0 bytes used free sapce 0 bytes not able to write data so what to do pls help me...
you have to make sure you are using the correct format for your drive i.e (+/-)
  • Read: 24X CD-ROM, 24X CD-R, 24X CD-RW, 8X DVD-ROM, 8X DVD-R, 8X DVD+R, 8X DVD-ROM DL (double-layer), 6X DVD-R DL (double-layer), 6X DVD+R DL (double-layer), 8X DVD-RW, 8X DVD+RW, 5X DVD-RAM, 4X BD-ROM, 4X BD-R, 2X BD-RE, 4X BD-ROM DL (double-layer), 4X BD-R DL (double-layer), 2X BD-RE DL (double-layer)
  • Write: 24X CD-R, 16X CD-RW, 8X DVD-R, 8X DVD+R, 6X DVD-RW, 6X DVD+RW, 5X DVD-RAM, 4X DVD+R DL (double-layer), 4X DVD-R DL (double-layer)
  • Read: 24X CD-ROM, 24X CD-R, 24X CD-RW, 8X DVD-ROM, 8X DVD-R, 8X DVD+R, 6X DVD-ROM DL (double-layer), 6X DVD-R DL (double-layer), 6X DVD+R DL (double-layer), 8X DVD-RW, 8X DVD+RW, 5X DVD-RAM
  • Write: 24X CD-R, 24X CD-RW, 8X DVD-R, 8X DVD+R, 6X DVD-R DL (double-layer), 6X DVD+R DL (double-layer), 6X DVD-RW, 8X DVD+RW, 5X DVD-RAM
Apr 09, 2011 | Acer Computers & Internet
My USB LG Super Multi Drive GP08NU6B is often either not recognised at all, or the contents of the CD/DVD can't by 'seen' by my Windows 7 Ultimate 64 bit PC in South Africa - even those files which were...
I have had a similar problem with this drive and windows 7. The device was not receiving enough power to operate. I found 2 solutions:
1) If connecting through a usb extension, plug in both USB connecters on the DVD's power cable.
2) Try plugging directly into the PC"s USB ports. Remember to always use the USB on the power cord that has the 2 wires connecting to it.
If this does not work, the drivers may have become corrupted. If so, let me know and I will walk you through it
Jan 03, 2011 | LG GP08NU6B DVDWriter Black External...
How do I change burn speed settings on an LG external GE20 super multi-dvd rewriter?
Settings are available in the software you use for burning the disk. Please check the burning options.
Jan 03, 2010 | LG SecurDisc 20x External Double-Layer DVD...
I have a LG GE20 DVD Rewriter Is a DVD+RW disc a format that is editable and suitable for this unit?
The LG G20 DVD Rewriter is an advanced external burner that supports 'editable' Rewritable DVD+RW disk.
As a generic comment, not all writable/rewritable media are made equal and problem with branded & unbranded disks are not uncommon, so stick to brands that work for you for your specific unit!
The following is the advertised support for your unit, hope it helps:
Reading Rate DVD-R/-RW/-ROM 16x/13x/16x/16xSL/12xDL max. DVD-RAM 2x, 3x-5x, 6x-12x DVD-Video (CSS) 4,8x max. (Single/Dual Layer) DVD+R/+RW 16x/13x max./ 12xDL max. CD-R/RW/ROM 48x/40x/48x max. CD-DA (DAE) 40x max. Burning Speed DVD-R 2x, 4x CLV, 8xZCLV, 16x PCAV, 20X CAV DVD-RW 1x, 2x, 4x, 6x CLV DVD-RAM 2x, 3x ZCLV, 3x - 5x PCAV, 12x PCAV DVD+R 2.4x, 4x, 8x, 12x, 16x PCAV, 20X CAV DVD+R Double Layer 2.4x, 4x, 10x, 12x ZCLV DVD-R Dual Layer 2x, 4x, 6x CLV, 10x, 12x ZCLV DVD+RW 2.4x, 4x, 6x, 8x ZCLV CD-R 4x, 8x CLV, 16x, 24x, 32x, 40x, 48x ZCLV CD-RW 4x, 8x, 10x CLV, 16x CLV, 24x, 32x ZCLV
Dec 28, 2009 | Computers & Internet
I have a MacBook, is the LG external dvd drive compatible
Both the LG GE20 Super Multi External DVD Rewriter & the LG GP08 Super Multi External Slim Portable DVD Rewriter are Mac compatible.They both use USB 2.0 interface to connect to the computer.
Jul 14, 2009 | LG Computers & Internet
Hl-dt-st dvdram gsa-t20n ata burn speed for cdr changes to 10x minimum automatic soon as i put a blank cdr in. i need to do slower burn Speed (4x) and i tried with different software and its always the...
Your drive doesn't support slower burning speeds unfortuately, here are the specifications for it:
Write Speed DVD+R 2.4x CLV, 4x ZCLV, 8x CAV DVD-R 2x CLV, 4x ZCLV, 8x CAV DVD+RW 2.4x, 3.3x CLV, 4x ZCLV, 8x ZCLV
(8x Speed disc: 3.3x CLV, 8x ZCLV)
DVD-RW 1x, 2x CLV, 4x, 6x ZCLV DVD-RAM 2x, 3x ZCLV, 5x PCAV(Ver.2.2) (16x Media: Not support) CD-R 10x CLV, 16x, 24x ZCLV CD-RW 4x, 10x CLV, 16x ZCLV
(High Speed: 10x CLV, Ultra Speed: 16x ZCLV, Ultra Speed plus: 16x ZCLV)
DVD+R DL 2.4x CLV, 4x ZCLV, 6x ZCLV DVD-R DL 2x CLV, 4x ZCLV, 6x ZCLV Read Speed DVD-R/RW/ROM 8x/8x/8x max. DVD-R DL 6x max. DVD-RAM (Ver.1.0/2.2) (Ver.1.0) 2x
(Ver.2.2) 2x, 3x, 5x
DVD-Video(CSS Compliant Disc) 4x max. (Single/Dual layer) DVD+R/+RW 8x/8x max. DVD+R DL 6x max. CD-R/RW/ROM 24x/24x/24x max. CD-DA (DAE) 24x max. Sustained Transfer Rate DVD-ROM 11.08 Mbytes/s (8x) max. CD-ROM 3,600 kB/s (24x) max.
Jan 28, 2009 | Computers & Internet
Computers & Internet Logo
Top LG Computers & Internet Experts
k24674
Michael Thomas
Michael Thomas
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
