My lens is stuck when i try to turn the power button a green light comes on and makes a beep sound but the lens will not go back in is their a reset button?
I just fixed my camera. I pushed the lens inside completely. took the battery out and put it back in. turned it on and off a couple of times and ready to go!! good luck!
If the lens on the camera is stuck out,
look to see if it's a little crooked. If it is, try to gently straighten it.
If it still won't retract, try to gently push it in as you turn the power
on. If it won't turn on (the green light blinks and it beeps 3 times) push
and hold the 'power' button and the 'play' button at the same time for a few
seconds - it worked for my S730. Good luck!
I dropped the camera on the table a couple of times, twisted the front of it. Suddenly the lens retracted into the camera, the beeping quit, and now I can take pictures again. The Samsung website is horrible.
cameras beep when it has a problem. most likely the lens get stuck or lens gear failed or motor drive gear to lens, or allot of other problems like it doesnt reconize the optical sensor.
the 3 beeping sound means that the camera has low battery capacity. the lens is stuck out because there is incorrect battery connection. there is an option on the camera setting for the battery type. try this one: -turn the camera on -click on Menu button -select options using left/right, up/down button -select Set up 2 -Select Battery type -Select Alkaline for non-rechargable or Ni-MH for rechargable -click OK button
this setting should be done when using camera for the first time and whenever you are switching battery types, from rechargable to non-rechargable and vice versa.
I had the same problem. Try to turn it on, 3 beeps and then it would shut down. Screen would come on for that time. Also, the lens was stuck open. It wouldn't close.
I twisted the lens (gently) and it appeared stuck. A gentle screw motioned seemed to free it. I hit the power button and it come on, but this time no 3 beeps and shut down. I then turned it off and this time the lens retracted and closed.
So, it appears that if the lens gets stuck open, it has a shut down feature that doesn't allow the camera to go further into its operation modes. I believe this stuck open problem occured on our camera when the batteries went low.
Again, a second of gentle twisting seemed to unstick it and with fresh batteries in, it was able to operate and shut down properly.
As far as batteries, I use the rechargeable Ni-Cad 2500 mA. They last a while.
Does the lens extend in either of these cases? If there has been some malfunction in the lens and it fails to extend the situation can cause the camera to power-off in order to protect itself. Some cameras show error messages before powering off, others do not.
Hold the camera up to your ear and turn the power on. Is there a series of mechanical sounds before the beeps? Hearing sounds but not seeing the lens extend indicates some sort of failure in the lens assembly. If you hear nothing then the problem most likely lies elsewhere, possibly a failed electronic component or something as simple as a loose connection.
Check with your manufacturer for any recalls or technical bulletins, and see if they will service your camera under warranty. If not there are a number of repair facilitys available on the internet who generally have better rates than out-of-warranty service at the factory.
David Millier
Advance Camera Repair
