Heating & Cooling Logo
Question about Haier Heating & Cooling
Water is coming out the front of our window air conditioner. it drips constantly. the air conditioner cools great. when you turn the air conditioner off, the water just pours out the front of the air conditioner. its leaking about 3 cups per hour out the front of the unit.
Posted by adkidd79 on
Anonymous
    Brigadier General:
  • 4,736 Answers
This can be caused by the drain hole in the drain pan (under the unit) is clogged or the unit does not have enough rear downward tilt to allow the water to flow to the rear of the pan and out thru the drain hole. The general rule of thumb is 1/4" to 1/2" downward tilt at the rear of the unit.
The drain hole can be hard to find, sometimes. As the clog will blend in with the hole. Persistence and patience help a lot in searching for it. A pipe cleaner works well to clear the clog.
Hope this has helped you and thanks for choosing FixYa.
Posted on Aug 22, 2011
Sounds like dripping water when on
Water, or in this case - condensation will be created and drip from the cooling coils inside the unit outdoors, if installed correctly. This is a normal condition. Like a cold glass of water sitting on a table or counter on a hot, muggy day; condensation will form. The amount of condensation forming on the glass - and cooling coils of the A/C - is directly related to the amount of humidity in the air.
Some A/C units have fans that not only force cool air out the front of the unit - but also spray condensate on the condenser coils (the coils that get hot and are visible from the outside) to help cool them down.
If water is dripping indoors - the A/C is tilted inward or drain holes on the bottom edges of the rear (outdoors) are clogged. Adjust the A/C support(s) so that it is tilted back (the bottom rear should be about 1/2" or 10mm lower than the bottom front) and inspect & clear obstructions from the drain holes as needed.
I hope this helps & good luck!
1helpful
It sounds like their is water in the blades and its not cooling my room
Tip the AC slightly downward on the outside so that the water can drip outside. If should be a hole for the water to drip away, make sure it's not blocked. Close your windows and doors. As long as cool air is coming out of the AC, it's working.
3helpful
I have a sharp window AC unit, model af-609x. does it have a drain hole? there is no water coming out of it, but when we take it out of the window we get soaked from water somewhere inside the unitl
All window air conditioners will remove moisture from the air if there is any. Most window air conditioners collect this moisture in the bottom pan of the air conditioner and attempt to evaporate the moisture. The evaporation process works as follows: First, the water drips down off of the cold evaporator coils on the front of the unit. Then the water collects in the bottom of the air conditioner base, the "pan." If the air conditioner is installed properly it will be tilted slightly back.
The water then collects near the back of the unit. On some units, the fan blade used to cool the rear condensing coils will have a rim on the outside of the fins of the blade. This rim, or "slinger," will come close to touching the inside of the air conditioner pan when the fan is spinning. As the water collects in the pan and reaches the depth necessary for the fan ring to touch it, the ring will lift some of the water up and the fan will blow it at the condensing coils. Because the coils are warm, they will evaporate the moisture to the outside.
While this is happening it is normal to hear water splashing and sloshing around. As long as there is no water leaking inside the room that is being cooled there is no cause for concern.
Never drill into the bottom of and air conditioning unit to "let the water out."
Rust colored water is dripping down outside of house, and when unit is on it sounds like constant water dripping.
condensation dripping out of my central air unit is dripping a rust colored water that has stained my house. What is causing this?
We have a window unit model ash08fas1 and it is leaking water into the window to our carpet. Does this model come with a drip pan or plug that needs to be moved? And how do we access it?
Look at your unit from outside the house. The back of the air conditioner should be slightly lower than the front. If it is level or the front of the air conditioner is lower it will drip into the house. Some window units have a drain for the water outside and some don't. Look for a hole in the bottom of the unit outside and if you find one make sure it is not plugged. Also dirty coils can cause a frost buildup on the inside of the unit. This will drip also. If this is the case you should see the ice buildup by removing the front cover or removing the front filter.
3helpful
My window unti is dripping water inside the bedroom room.
there could be an obstruction in the bottom.remove it from the window and remove the case.check for anything obstructing water flow (condensation) to the outside.
1helpful
Sunbeam air conditioner
It is normal for water to collect in the lower base of an air conditioner. See the section entitled: "There is water sloshing around inside." If water leaks out the front it is usually because the unit is tilted forward in the window frame. All air conditioners should be installed so they tilt slightly back to allow for proper removal of the condensation collected.
There is water sloshing around inside All window air conditioners will remove moisture from the air if there is any. Most window air conditioners collect this moisture in the bottom pan of the air conditioner and attempt to evaporate the moisture. The evaporation process works as follows: First, the water drips down off of the cold evaporator coils on the front of the unit. Then the water collects in the bottom of the air conditioner base, the "pan." If the air conditioner is installed properly it will be tilted slightly back.
if this helps please give me a fix ya
3helpful
Water Leaking
Dear Customer,
The likely reasons for a leaking AC are...
1) Improperly installed.
A window air conditioner must be slightly lower at the rear than the front. This allows the water being removed from the room to drain to the back of the machine. A difference of one inch is sufficient. This is always the first thing to check. Many are improperly installed in the haste to get relief from the heat. If installed too low at front the water will flow into the room rather than outside. If installed too low at rear, water can roll out front edges before has chance to exit towards rear drain.
  1. Icing up.
    Water being de-humidified can turn to ice if there are problems with the cooling system. There are many reasons for an air conditioner to produce ice. Remove front grille while machine is operating. If ice is present on the cooling coil you will probably need service. For more information see our other article: Why window Air Conditioners Ice up.
  1. Air leakage around air conditioner.
    If warm air is able to enter around the air conditioner it will encounter cooler, dryer air. When they meet condensation will occur. If water leaking from front of air conditioner inspect to see if dripping from body of machine, or water droplets clinging to front area. To test, operate machine for 30 minutes and then use flashlight to check under front edge of base. Small water droplets here indicate an air leakage problem. Add foam insulation to stop warm air from infiltrating.
  1. Drain hole blocked.
    Rear of air conditioner base has a drain hole or groove to allow water to escape. If becomes blocked water can back up. To test, operate machine for 30 minutes and then inspect if draining properly. If appears blocked use a small piece of wood to open drain hole at rear of metal base. CAUTION: Never be tempted to drill holes into the air conditioner body to relieve water pooling. Severe damage can result.
  1. Internal drains blocked.
    There are small passageways that allow water to drain from front of air conditioner to the rear. If they become blocked water will pool at front of machine and overflow onto floor. If this happens the air conditioner will require removal from window and servicing.
  1. Outside temperature too cold.
    This occurs at end of cooling season. If outside temperatures drops below 60 degrees Fahrenheit at night the cooling coil may ice up. If no leakage at bedtime but water in front of machine in morning, suspect this problem. If this problem suspected turn off machine before bedtime and restart as day warms. Alternately, operate machine at night with selector switch in ‘fan only’ position. This will circulate room air during night but not allow cooling.
Hope u find this useful. I'll be thankful if u could rate this. thank you.
Top Haier Heating & Cooling Experts
Tom Chichester
Akbar Mughal
Akbar Mughal
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
