Question about HP Compaq Presario CQ50-110US Laptop
The hinge that holds the laptop screen broken.
Posted by nadeeshan26 on
Chris Hingee
  • HP Master
  • 32,281 Answers
Laptop hinge wont move
I would loosen or unscrew the 8? screws that hold the display on, this will loosen it off without everything coming apart, then tilt the screen down, lift the from the bottom of the screen, pry without breaking, take that panel off and see if you can replace or find the part that came out, it maybe screws or another piece. You can probably put it back together if it fell out, then just put the screen plate back on.
Aug 23, 2013 | Fujitsu Siemens Computers & Internet
Dell latitude c610 broken hinge
go www.dell.com give your service tag, model and download your instr. manula and service manual , parts and fix it.
God bless you
Sep 27, 2012 | Computers & Internet
A hinge seems to be broken or loose on the laptop screen, how can i fix it
Many laptops have plastic coverings on their hinges. You can can pop these off with a screw driver and sometimes you can reach the screws to tighten the hinges from here. You may be able to tell if the hinge is broken from here as well. Many times, though, the screws holding the hinges in place are located on the bottom and you will have to remove the portion of the case that is covering them. This usually means the entire lower portion of the laptop case to access these screws.
Dec 20, 2009 | Toshiba Satellite A1O A15 A20 A25 A30 A35...
Broken Inspiron 1525 Lid
hello
To fix your laptop follow the steps given below.
  • First of all as your hinges are broken you have to buy a pair of hinges for your laptop model.
  • This hinge includes the whole assembly made up of metal with a part which attaches your screen to the laptop.
  • Now you have to open up your laptop from the backside and disassemble the upper side.
  • This will make you see the part which detaches tour screen from the laptop.Just remove the screws and your screen will be completely detached.
  • now you can replace the damaged hinges with the new one.
  • you have to remove four screws for one hinge.Two screws supporting the screen and two attaches the screen with the laptop.
  • so remove these screws and replace the hinges and pack the laptop again.
And the lines are basically due to the movement of loose connector. So while fixing please fix the connector also.
Thank you
Aug 21, 2009 | Dell Inspiron 1525 Notebook
Screen on Sony VAIO PCG-SRX99 needs to be tightened.
you will have to take the bezel front plate of the screen off and check to see if anything there has broken from the hinges. there are usually two-three screws holding the hinge to the screens back cover and two-three holding it in place on the base of the laptop. if all those are intact you will need to replace the hinges.
good luck
ruben
Apr 06, 2009 | Sony VAIO SRX99 Notebook
Broken Hinges
you have to change your hinges.Plz visit to your nearest service station.
Mar 14, 2009 | HP Pavilion dv6000t Notebook
Broken laptop screen HP Pavilion ZV6000
I have a HP Pavilion zv6000 laptop too, and I have the same problem. A year ago, the screen was getting loose and finally it just broke. Won't stand up. I've been propping it up against a wall for a year. I can see what is wrong: my laptop has gotten so hot that the back of the laptop where the hinges are has warped and ruined the hinges. Do you notice that? The split in the seem and the actual bend of the plastic? Anyway, the computer itself works perfectly. I was going to buy new hinges and replace them myself, but it was too much of a hassle, and I needed a new laptop anyway. The hinges are inexpensive. And the laptop isn't TOO difficult to take apart (search for the manual. it's easy to find). I took it apart with my Grandpa, and he's old, and I'm a girl. (okay, sexist, gender...ist.) I actually received a new laptop as a gift. Luckily. No solution, other than replacing hinges. I just wanted to let people know I too had the same problem.
Aug 13, 2008 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
Hinge gave out
Ebay the model and see if someybody is parting your model out. The "hinge" can cost up to $100 for one side if purchased new. I needed both sides and the diplay clamshell for my Toshiba and got it for $35, including a signal cable and invereter.
Apr 29, 2007 | Compaq Evo N1020V Notebook
HP Compaq Presario CQ50-110US Laptop Logo
188 people viewed this question
Top HP Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
