Hello. 1. Go to START -> CONTROL PANEL -> SOUNDS AND MULTIMEDIA
PROPERTIES -> AUDIO TAB 2. Make sure that in the Audio tab your soundcard appears as
the Preferred Playback device with USB Audio or
INport as the Preferred Recording Device. There
should also be a check next to the option 'use only preferred device'. 3. When you start LPRecorder you should also make sure that
Recording Device is set to USB Device or INport
and Playback Device is set as your soundcard and
that there is a check next to the option Simultaneous
Playback. Hope this helps.
There may be a conflict with your sound card.
From Xitel:
Here a link that should help. Your Playback device should be your soundcard with the Recording Device set to USB Audio or INPort. Select "Set Default".
http://www.7tutorials.com/how-change-def...
In SOUNDS & AUDIO DEVICES USB Audio is the default playback, but the only option for Recording is SoundMAX HD Audio.
