Refrigerators Logo
Question about Maytag Refrigerators
Why would crushed ice come out when cubed ice is selected?
Posted by tiffany_harm on
Anonymous
  • Maytag Master
  • 43,501 Answers
There is another set of blades that pull in to crush the ice... they are stuck in the crushed position causing you to get crushed ice always...
See if the solenoid is stuck or bad that moves the crushed ice blades...
heatman101
Posted on Aug 22, 2011
My lg refrigerator will only do crushed ice not cubes
crushed ice is better for your Margareta anyway... but chances are the switch or button that allows you to select crushed or cubed is broken...
2answers
LG ice maker will not dispense cubes without crushing them
Check the evaporator system, that release the cubes, when that does not work the cubes stay stuck inside.
Ice maker problems
Not sure which refrigerator you have but on mine when you select cubes there is a baffle that is pulled out of the way making the opening large enough to allow full sized cubes to pass. When you select crushed the baffel is left in place forcing the ice to pass through the crushing section. My guess is they are all probably about the same. So either the baffel peice on yours is missing, electrically stuck. Hard to say for certain with out seeing it.
1helpful
My samsung rfg297aa dispenses crushed ice whether its set on crushed or cubed. why will it no longer dispense cubes?
This answer probably comes too late for you (you posted the question 9 months ago), but I want to record it here for posterity, since I had the same problem, and searching on Google for it brought up your question.
Anyway, I managed to fix this very problem by removing an ice cube that was wedged in the ice dispensing mechanism. The way this unit works is that it pushes the ice cubes through the mechanism, which always rotates the "crushing blades". When you select "cubed" ice, a lever opens up the exit chute wider, which causes the blades to simply push out the ice cubes as they pass through. When you select "crushed" ice, the lever closes the "exit" for the ice cubes to be narrower, so that the ice cubes can't be pushed through by the blades, and instead get crushed by them. I had an ice cube wedged in there that had the same effect of closing the exit to be narrower. Removing it fixed the problem.
You might want to collect all the ice cubes that have accumulated in the ice bucket in a container, empty the ice bucket, clean out the mechanism from any obstructions, and then put the ice cubes back into the ice bucket.
1helpful
Fridge Freezer model KA58NP90 Ice maker problem
What is most likely your problem is the crushed ice solenoid. This solenoid, which is located next to the auger motor behind the ice bucket, is failing to actuate when you request cubed ice. Its "home" setting is crushed, and actuates to allow cubes past the crushing mechanism in the bucket. To be certain its the problem, remove the ice bucket, and tape the door light switch in the closed position. actuate the ice dispenser lever, for both cubed and crushed ice. you will see a square hole next to the rotating fork, when you select cubes, it should open. If it does open, there is something wrong with your ice bucket, perhaps the arm is broken, or the door inside bucket is off its snap in type hinge or broken altogether. If it doesnt open, replace the solenoid
Expert Refrigerator Repair Service in Chicago and Suburbs
Mar 20, 2010 • Freezers
Crushed ice option don't work properly . samsung RS2530B
if it new call sears for service...with crushed ice the augar moter turn the other direction... it must not be turn the other way could be a switch in the control...
let me know for it help if NOT please let me know and I will be glad to do more in depth.
2helpful
Dispenses crushed ice instead of cube ice
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid
Cubed Ice selected, crushed ice comes out
ice maker works. water thru the door works. lock works. light works, alarm works.
when i try to get crushed, ice cubes or quick ice.
nothing happens
3helpful
Dispenses crushed ice and will not dispense ice cubes
Admiral Fridge Freezer
We had thought this was a free service...??? Yes, we fixed it ourselves, after trial and error. We pulled out the ice bin and there is an arm that is moves back and forth beside it. It had frozen up. That is the ice crusher. Thaw it out and it is fixed. By the way, the above posting was not by us--ours stated that our ice crusher did not crush ice anymore. Instead, cubes came out...
Open Questions:
0answers
Maytag Side by Side RSW22EO Refidgerator Freezer , not cold enough. I have a older Maytag (Model No. RSW22EO) Refrigerator/Freezer that uses "R-12 Refrigerant". 3 days ago I noticed it was not keeping things as cold as usual. I tried setting the temperature adjustments to their lowest setting and checked back 24 hours later, and while it did get the freezer to keep things somewhat frozen, both sides (fridge and freezer) are certainly not getting cold enough. I have not checked actual temperatures, ( as I don't have a thermometer), but it is obvious it is not working properly. I pulled the fridge away from the wall and checked to see if dust had excessively accumulated on the radiator and condenser, but since I blow it out yearly, there was very minimal dust accumulation. To my novice ears and eyes, the compressor and fan appear to be working properly, but I can only attest to compressor having a slight vibration and the fan is spinning, but of coarse, that does not meant they are actually functioning at peak performance. My guess is it is low on R-12 Refrigerant, which will require a professional with a EPA 602 license, not to mention limited availability and the ridiculous cost of R-12 refrigerant. If you have any suggestions on how to troubleshoot the problem, I would be very grateful. I have only a basic multi-meter for electrical testing, and I do not have any means or skill to test refrigerant levels. REPAIR PROCESS: Well, since no one had an answer, I thought I would give an update: well, the problem got progressively worse as the freeze was now unable to keep things frozen and the fridge side was not cold at all, so I decided to tear into the project and see what I could find. DISASSEMBLY: To gain access to the parts, I needed to get into the back of the freezer from inside of the freezer compartment. First I removed all the wire basket drawers from the freezer compartment, then I unscrewed the drawer guides from each side of the freezer's inner side walls (these are held in place with two 1/4 inch hex drive screws per rail), Next I removed the Ice maker's plastic bin (actually, I removed this years ago so I cannot recall how I got it out, but I think it just pulls out without any fasteners, but don't quote me on that). Located near the top of the freezer compartment's back wall is a rectangular housing that has the light and the ice maker's motor, this has to be removed as well. It is held in place by 6 stainless Phillips screws (2 on each side and two more along the top edge). Note, to be able to access these fasteners you will need to carefully remove the light's diffuser lens by slightly compressing it to get the tabs on the top and bottom edges to release from the slots (there are not any fasteners in the light lens, and also unscrew and remove the light bulb. Then you should be able to tilt forward/downward the light/motor housing and wiggle it out, but if you cannot get it to come out, you will likely need to remove the entire ice-maker and the panel above the housing we are trying to remove. I was able to get it out, so I did not remove any other parts thus far. Next there are 7 stainless Phillips screws holding in the main back panel (that covers up the condenser coils), 3 screws on each side and 1 centered at the top. Once the screws are removed, simply grab the panel at the top edge, lift it about an inch or two, and then pull it out towards the front, and set aside. DIAGNOSING: Well it became immediately apparent what the problem was, since both the upper and lower condenser coils were completely frozen and frosted over. It was not thawing out as it should. Near the top is a black round thermostat with two wire leads ( one white wire, one blue wire), so before defrosting the freezer, I unplugged the fridge from the wall outlet, and using a multi-meter i tested the thermostat for continuity between the wire leads. Note: this must be done when the temperature on the Thermostat is between 25 and 40 degrees Fahrenheit. If you cannot test it in the freezer, remove it and stick it in a different freezer before testing. Well, my thermostat was fried, but that was not the only problem... There are two heating elements (glass tubes with spring like heating coils sealed inside), which are located below each condenser coil. one is in the middle and the other is at the bottom just above the drain pan/funnel. Eack one is held in with two 1/4 inch hex drive screws. you may need to bend the metal on each side of the freezer to get the heater assemblies out. Prior to removal. you an test the continuity of the heating elements by tracing the thicker wires back to the jumper-board next to and to the right of the thermostat. Disconnect the spade connectors of these wires and test for continuity. My continuity test failed, so these need to be replaced also. Since these marts are useless, and the wiring connecting the heating elements was entrapped in the condenser coils, I just cut the wires and pulled them out. Upon further inspection, it was clear one of the coil-spring heating elements inside the glass tube had a beak in the middle, and each tube lost it;s seal allowing moisture to enter the glass tubes of the heating elements. I am awaiting parts, but once installed, I am confident the freezer will go into it's scheduled defrost cycles as expected, and all will be working as it should. The only other thing that could have failed would be the defrost timer, but I am not sure where that is or how to test it. I read it may be located behind the front grill below the doors, or it is inside the fridge side near the temperature controls. CONCLUSION: To be determined after I replace the failed parts.... .
Top Maytag Refrigerators Experts
Marvin
Marvin
Pieter Vleeshouwers
Pieter Vleeshouwers
vince
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
