Question about Zanussi 24 in. LS6E Free-standing Dishwasher
Does not start cycle just hums gianni dishwasher
Posted by gypsy99 on
Ron
    Sergeant:
  • 191 Answers
Sounds like it is not getting water or a solenoid is stuck or broken.
Posted on Aug 22, 2011
Dishwasher hums intermitantly and after the wash cycle is completed
Sounds like you have a bearing going out. It could be in the system pump or the rotating washing arms. I would suggest getting ahold of Kitchenaid's customer support and relay when during which cycle the noise occurs and they should be able to identify whats going wrong.
Jan 22, 2014 | KitchenAid KUDE70FXPA Builtin Dishwasher
Samsung dishwasher dmt 300rfb wont drain and is humming
Hello Randy Lowe,
There is an EXPECTED INITIAL failure period
on new equipment...!!
Use your warranty...
Brand new = Take it back & get a GOOD ONE.
Carnac the Magnificent
Apr 22, 2017 | Samsung DMT300RFS Builtin Dishwasher
Loud humming just started during wash cycle
Humming can be simply due to a mechanical vibration when the wash pump is running. Alternatively it could be the sound of the detergent door solenoid which might be stuck.
Will need make and model number of dishwasher to give further advise. Does the dishwasher complete the cycle and drain out the water?
Feb 13, 2011 | Dishwashers
GE diswasher hums but will not start cycle and starts to smell ho
Hi, Have your freind check and see if the water supply line under the sink has been turned on. The hum you are hearing could be the inlet valve. Please let me know if this has been helpfull or if I can assist you further.
Thanks
Vic
Jul 17, 2009 | General Electric CDW9380N Built-in...
I have a maytag washer (model -dependable care) and when we start the wash the motor just hums, the water does not fill, if we move the timer switch to rinse the motor engages and the unit works entire the...
Check your fill tubes remove the hoses and see if the filters are plugged, you are not hearing the motor humming. You are hearing the watervalve humming, the motor will not start until the tube is full of water.
Jul 16, 2009 | Maytag MDB6650A Built-in Dishwasher
Gianni Dishwasher won't switch into cycle and just hums.
I have found out that it seems to be the drainage pump, have real problem finding a new one.
Jun 03, 2009 | Zanussi 24 in. LS6E Free-standing...
Bosch dishwasher timer sticking
I have been told to replace the timer which I am looking to do the same to my machine!
Mar 24, 2009 | Bosch Dishwashers
Bosch dishwasher timer freezing
There is a recall on the control board of many of these models, butyour problem is likely not related. It sounds like a plugged drain system or a possible bad drain pump. That's why you are hearing the pump running constantly. I have written a guide to help. It is here. Thanks!
Mar 24, 2009 | Bosch Nexxt 300 Series WFMC2201UC
LOUD HUMMING AFTER WATER FILLS AT START OF CYCLE
Sounds like you have something in the sump/motor. I could lead you through it on a chat session but too much just to type. Let me know if you would like me to do so.
Mar 04, 2009 | Whirlpool 24 in. GU1200XT Built-in...
Loud humming noise when dishwasher is filling up with water
your model is pretty new. just so you know your warrenty is 1 year parts and labor. 2 years on parts. it should not cost that much money.
there are two components that start before the circulation pump.(wash noise you hear)
first sounds you hear will be the drain pump. usually rattling noises if something is in it but it can make a hum noise if something is jamming the drain propeller up. which is accessible with a T20 torx driver. take the filters out and the mesh filter. and unscrew the screw in the base towards the left. pull out whatever is lodged.
the other humming sound can come from the next component that activates is the watervalve. make sure you dont have a kinked water intake line. otherwise its a bad valve. i have had to change a few of those water valves out already but not for a hum noise on your model. you have a new style water valve. when brands make new parts we get problems fast sometimes..
Feb 14, 2009 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Zanussi 24 in. LS6E Free-standing Dishwasher Logo
160 people viewed this question
Top Zanussi Dishwashers Experts
Paul Carew
Renee Knafel-Bullock
ray gallant
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
