Question about GPX KL858S 8.1 in. Under Cabinet TV
To set the clock on the unit, have the TV connected to power but not on. Then press and hold Mem/Clck Adj on the TV (it's the third button from the right in the top row of controls). Use the adjacent Tune/Clk (up/down arrows) to set the clock for 12 or 24 hour time. Then press Mem/Clk Adj again to adjust the hour with the up/down arrows. Press Mem/Clk Adj again and set the minutes. Press Mem/Clk Adj to save the time. The original remote also has these buttons. Mem/Clk Adj is also labeled Set and is the furthest right button on the second to bottom row of the remote. The Tune/Clk buttons are the DN and UP buttons on the left of this row.
Use the Tune/Clk arrows to change the radio channels after pressing the radio button (second from the right on the bottom row). When you press the TV button (first on the right of the bottom row) to watch TV, then you need to use the Channel up/down arrows at the top and bottom of the ring control on the far right of the TV or the Channel + and Channel - buttons on the remote. On the remote, the Channel + button is below the timer button which is below 9 in the keypad section. Enter is below the Channel + button and Channel - is below Enter. Make sure that the TV is in the correct mode for your signal (ATSC for OTA and NTSC for analog cable) by pressing the TV mode button. If you are using a set top box, you will need to change the channels at the box.
Press the TV Menu button and then go down the list to Time to set the time zone for the TV. Press Enter to save the setting. Use the TV Scan button to get a list of available channels before trying to change channels.
The manual for the GPX KL868S is available from GPX at the product page: http://www.gpx.com/store/p/287-KL858S.aspx . The direct link to the English version of the manual is: http://www.gpx.com/owners_manuals/KL858S-IB.pdf .
I hope this helps.
Posted on Aug 22, 2011
Jan 27, 2014 | Rio Nike PSC Communicate (14 Channels)...
Jan 02, 2011 | Disney DT1350-P 13" TV
Apr 13, 2009 | RCA DRC8320 DVD Recorder/VCR
Mar 13, 2009 | Televison & Video
Jan 04, 2009 | Symphonic WV806 DVD Player/VCR
Dec 16, 2008 | Motorola AXU4100 (10 Channels) 2-Way Radio
Dec 23, 2007 | Philips 14PV225 14 in. TV/VCR Combo
Sep 08, 2007 | Sanyo DRW-500 DVD Recorder
May 24, 2007 | Sharp VC-A560U VHS VCR
Feb 20, 2007 | Philips 14PV225 14 in. TV/VCR Combo
248 people viewed this question
