Question about Dell Dimension 4700 PC Desktop
Replaced 80gb with 500gb sata wd green also have 500gb sata as second drive bios level 10 sees both in setup but nothing is available in boot including well used cd drive- system dell dimension 4700- any ideas how to get this thing to boot.
  • 443 Answers
Did you remember to set one drive as a master and the other as a slave driver?
To do so. Removed the drive and look on either the front or back and it'll give you the jumper set up.
Master is the primary boot drive and the slave will the be media, documents drive
Posted on Aug 22, 2011
Dead hd wd caviar 80 gb
Is the "dead" hard drive 80GB? or 500GB?
I presume you set up this hard drive as the second hard drive, or as an external drive. You can do these:
1. Disk Management (check the readablility):
Control Panel, Administrative Tools, Computer Management (please run as administrator; right click it), Disk Management. Is this hard drive info exist in this screen? If it is, then the hard drive is not dead.
Click on the hard drive info, right click, and you can do some actions (format, expand the volume, assign a drive letter, etc.)
2. If necessary, test and fix it using Norton Utilities (download and run it):
http://download.cnet.com/Norton-Utilities/3000-18512_4-10907620.html
Feb 20, 2014 | Western Digital WD Caviar Green WD5000AADS...
I installed a hitachi 500gb hd in my computer using a serial ata cable , but when i turned the computer on I get an error message "Reboot and Select proper Boot device or Inster Boot Media in...
your computer is trying to boot from the new istalled drive instead of the drive containing the operating system,
you could try swapping the SATA cables on the mother board, or enter the BIOS by rebooting and at start up, holding the correct key (acording to the manual) then look for BOOT DEVICE some where in the BIOS menu, change the boot device to the correct hard drive (the one containing the operating system)
Have fun!
Dec 31, 2010 | Hitachi 500GB 7200RPM 16MB BUFFER SERIAL...
Picked up a HP dc7100 but will not boot from sata
You should have an option on the dc7100 in bios to enable sata in the devices section. Mine always worked fine with sata. If nothing else works remove the security chip, reset the cmos and reboot with the Hard Drive connected and it should connect. If that doesn't work Try flashing the bios just in case it got corrupted.
Mar 12, 2010 | HP (REFURB) HP DC7100 XPP P4 3.2GHZ 80GB...
ASUS K8S-MX Motherboard, but when I connect IDE
How were the partitions created on the SATA? Are they RAID configured from the other system? Does the new motherboard have the same support for your HD as the other system? Check the setup in the BIOS screen on both systems to make them identical as much as you can. According to Tom's Hardware: "In the SATA port configuration place you have up to four "mode" choices: IDE (or PATA) Emulation, native SATA, AHCI, or RAID." Check this section. [email protected]
Dec 13, 2009 | ASUS K8S-MX Motherboard
Does 206M supports SATA Drives 500GB as well as
Enter BIOS SETUP, and check the "boot order" (after connecting the SATA drive) -- ensure that the SATA drive is *NOT* the *FIRST* boot-device.
Oct 23, 2009 | IBM eServer xSeries 206
Brand new Seagate barracuda 500GB SATA hdd not detected
http://www.seagate.com/staticfiles/support/downloads/firmware/ http://atulchitnis.net/files/seagate.pdf
Jun 20, 2009 | MSI Mother Board (MSM865PEN2V) Motherboard
Switching from 40GB IDE HDD to 500GB SATA HDD. SATA won't boot.
Hi there
No there is no need to change any jumpers on a sata drive, go into the bios settings and tell the bios to boot from the western digital drive only.
Good luck and thanks for using Fixya!!!!
Feb 09, 2009 | VIA MSI: MSI PT8 NEO-LSR P4 PT800 DDR400...
ASUS P5LD2 Raid 5 locks windows at MUP.SYS
A stab in the dark. Sound like the MB BIOS expects and is written to have the OS on the  IDE  slot. After that I would add one SATA drive at a time to see if it matters and to see if one of the drives are causing the problem.
Jan 05, 2009 | ASUS P5LD2-VM Motherboard
HDD Installation
Hi gravni,
The bios (MUST see the drive). If the bios does not see the drive neither will windows!
The down below port (as you mentioned) is for IDE devices. IDE1 by name. Use your ATA IDE port for the slower IDE drives or cd-rom drives. (This board does not have a second IDE port).
If the WD drive is a SATA drive connect it to the SATA 2 port. See your manual. Go to page 1-4.
As show in this pic below.
2711d19.jpg Is the WD 500Gb drive SATA or IDE?
It's suggested when adding a new drive into a working system, the user should setup the drive by using the manufactures guide. Click on this link & download WD's pdf file:
http://www.wdc.com/en/library/sata/2079-001042.pdf
You mentioned the drive is hot. This only means it is running.
Include in this post the model number of your WD drive? So I can check the specs.
Mike
Oct 28, 2008 | MSI P965 Platinum Motherboard
Dell Precision 380
So the 80GB drive is an IDE drive, right?
Different manufacturer's have different BIOS' so I can't say with certainty what you'll see in yours, but on my ASUS motherboards I have a one of three settings:
PATA
SATA
PATA+SATA
When I run both IDE and SATA drives I need to use the third setting. I sounds like you're shutting off the PATA when you enable the SATA so there's no drive from which to boot.
If I misunderstand your problem please let me know.
Dec 22, 2007 | Dell Precision 380 P4 Dual Core 3 GHz...
Dell Dimension 4700 PC Desktop Logo
305 people viewed this question
Ekse
Thomas F. Schneider
