Question about Hobart HL600 Legacy Stand Mixer
Pushing the start button, a code of 6_9d appears. What is the issue and how can I fix this?
Posted by mg0190gm on
vestxre
    New Friend:
  • Hobart Expert
  • 120 Answers
It's telling you that the bowl guard is open. If the bowl guard is in place and closed then you could have a bad bowl guard switch.
Check www.hobartservice.com for your local Hobart office.
Posted on Sep 13, 2011
  • Mike Koxbig
    Mike Koxbig Jul 27, 2014
    what if i get continuity on the magnetic switch but the same error keeps showing up
  • vestxre Jul 27, 2014
    Check the stop switch, it can cause the same error.
How to fix a kitchen aid mixer that does not turn off
The answered suggestion on this post might be able to help you:
Doesn actually turn off Mixer
Mar 07, 2015 | Food Mixers
I have kitchen aid stand mixer and i can't get the beater to attach because the button is stuck??
The button doesn't move. You must push the beater up beyond th notch and turn it while pushing up.
Jan 14, 2013 | KitchenAid KITCHEN AID 5 Quart Artisan...
The release button to raise the body to take off the beaters will not release. I can't get the bowl out or remove the beaters. Please help.
Put a few drops of cooking oil in the holes the the beaters are inserted inMake sure to unplug the unit. Pushing the button, work the beaters pulling lightly. Good Luck
Aug 11, 2010 | Sunbeam 2370 MixMaster Series Stand Mixer
My Hobart mixer is hard to start. I have to keep
take off the side cover where gear shifter is, you probably have the original arrow hart contactor in there ,that part is obsolete but you can get a kit from hobart to upgrade the control circuit
Nov 29, 2009 | Hobart H600 Stand Mixer
Mixing blade on KSM50PPWH model will not release? Any ideas?
AHA, been on one of these before. Turn the attachments upward and put a little wesson oil in the sockets the attachments slide into. Depressing the release button several times in the process and pushing the attachment in. Make sure it is unplugged. Good luck, Ned
Sep 23, 2009 | Food Mixers
How to disassemble Black & Decker MX50 PowerPro Mixer
You can remove the handle-back by gently prying the rear clips down and away. But the problem is the power boost button; it has a fork that goes down the left side and snaps over a micro-switch. You need to get that off since there is not room for all 3 buttons (eject, variable speed, and boost) to slide through the handle. A small probe inserted from the top and pushing on the left side to the rear might do it. Or just pry the boost switch upwards; that's how I got mine apart. My problem was the boost microswitch was bad and provided a poor connection. As a result, the beater only ran intermittently on regular switch positions. I solved it by bypassing the boost micro switch. The beater now only runs on the regular speeds but that's fine by me.
Nov 10, 2008 | Black & Decker MX50 PowerPro® Mixer
Hobart Mixer wont start
I apologize but im unable to answer yours or any others at this time.Ive been hijacked by another user on this site that is dropping my rating.I contacted [email protected] (manager) of this site about restoring my account but has yet to do so.If my request fall on deaf ears maybe if you can email him and explain that its hard to get info on any hobart products and im the only one that is a hobart tech answering questions for FREE!!As soon as this matters resolved i will continue to help people as ive been doing for a year on this site.
Apr 01, 2008 | Hobart HL600 Legacy Stand Mixer
Hobart HL600 Legacy Stand Mixer Logo
366 people viewed this question
Top Hobart Food Mixers Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Lawrence Oravetz
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
