Question about Dream Maker Spas Dream Maker Ez Spa Hot Tub
Coleman spa horizon 400 flo is flashing. Just filled spa with water.
  • 1 more comment
  • Anonymous Aug 21, 2011
    it's flashing error code "Cool FLO". (Coleman Spa Horizon 400)
    Fixed it by bleeding air from small pump.
  • coachjordan
    coachjordan Oct 29, 2012
    how do you bleed air from the small pump, I got the same problem
Marlon Deza
  • 670 Answers
please try to double check the water level. Alot of these spas are very sensitive to the water level. One other thing you can check is the terminal board connections. Some times these burn out. Let me know if any of these helps.
Thanks!
Posted on Aug 21, 2011
  • Marlon Deza
    Marlon Deza Aug 21, 2011
    Additional information:
    Please check the Circ Pump and the other pump too. Make sure that nothing is blocking the flow and see if the Circ pump impeller shaft is hooked to the motor or if it's broken.
    If the impeller shaft is broken you would have to order a replacement to get it working again.
    Thanks!
  • Marlon Deza
    Good Job on getting it done, usually a blinking FLO message means that the pumps are not working right.
Derek Carden
  • 783 Answers
Whats the problem.?
FixYa Support
Please accept solution and rate 4 thumbs up! Thanks for your feedback!
My spa pool is coming up with FLO flashing where the temp is shown, its a sunbeam and now wont hold temp
when a spa shows flo in a alarm message (like yours) this is a indication that the flow sensor is telling you that it has not enough flow thru the filters this most times disables the heater so it wont become overheated , Most times its caused by dirty filters or a foreign object getting past them , but ive also seen very poor water chemistry cause a false showing of this message , this usually requires a sensor replacement and correction of water chem to correct this
Aug 30, 2015 | Pool & Spa
Ned a cap for the filter pump
call thes peope
Aqua-Man Aquatic Service
6890 N. Camino Martin, Suite #110
Tucson, AZ 85741-2273
http://www.aqua-man.com
[email protected]
Office: (520) 572-9840
Fax: (520) 572-8479
Toll Free: (866) 400-2782
Jul 24, 2012 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
When my spa is on heat mode pump on Low Speed it will not heat up. It says FLO and flashes do I have an air lock ??? Just changed pump a month ago.
FLO is a common signal for insufficient water flow through the heater tube. Do you see the low speed pump working? If you do, then try removing your filters, if FLO goes away then replace your filters with new ones. If not, your flow switch may not be working. You could have a legitimate flow issue caused from a clog or air-lock though.
Dec 17, 2010 | Qca Spas Majestic Series Aruba Xl Hot Tub
I have a coleman emerald 455 hot tub and I have managed to lock the electronic control panel. How do I unlock?
press program and then mode, it will display "0" and will be unlocked. u locked it by pressing program twice
Nov 05, 2010 | Pool & Spa
Refilled my hottub and now there is a ''FLO'' signal and the heater will not come on. Pumps and jets work fine.
simple fix its one of two things you did not prime the spa when filling it meaning that u just did not lay a hose in the spa then fill it you always need to prime the heater first along with the circ pump if you do not you will get a thing call airlock which is what it sounds like air in the main circulation pump for the heater.Also could be that u removed the filter while you still had the spa running an clogged the circ pump or it could be the flowswitch. Sounds like u might have a sundance spa an if the flo is flashing its either the air lock or your pump went or its clogged if the flo sign is not flashing then its the flowswitch but in that case w/a solid flo nothing would b working. To fix the airlock just shut the power down an take your hose an force water into the intake side of the filter area this is what u should always do 1st when you fill it that how you prime yuor pump an when fillin it all the way it best to fill it through the other end of the filter just put the hose into the filter tube w/the screw on it.IF THATS NOT IT THEN FEEL YOUR CIRC PUMP IT WILL BE THE SMALLEST PUMP IN THE SPA IF U CAN NOT TOUCH IT FOR MORE THEN A FEW SECS. THEN IT WENT ON U OR IT CLOGGED
Jan 29, 2010 | Jacuzzi RapidHeat In-Line Heater U395000 [...
Pump shuts itself off
Fill the tub with water, disconnect the supply pipe to the pump and ithe head of water should push out any air
Make sure you can get the hose back on easily before you fill the tub other wise you are going to get wet
Oct 09, 2009 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
I need an owners manual for a Coleman Spa Horizon series 447
Chuck, did you find the manual? If not I have one with my spa maybe I could copy it for you.
Ron
Sep 04, 2009 | Coleman Sport & Outdoor - Others
Need owners manual for coleman spa 208 or 408
Go here and print it out. Nancy
team.maaxspas.com/manuals/horizon%20series%202000.pdf
Dec 19, 2008 | Coleman 10' X 10' Sundome Tent 9160K101
Dream Maker Spas Dream Maker Ez Spa Hot Tub Logo
1,068 people viewed this question
Top Dream Maker Spas Pool & Spa Experts
john h
Vincent G
Vincent G
Tom Chichester
Are you a Dream Maker Spas Pool and Spa Expert? Answer questions, earn points and help others
