SOURCE: toshiba 43A10 projection television
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
SOURCE: dim picture from one broken lamp??
The red CRT is most likely not the culprit. If water got on to any of the boards such as the red CRT driver board it could damage it wich also at the same time can load down voltages (200 volts etc) that can have a global affect on the other CRT's. Changing any on the CRT's by the average consumer is NOT recommended because you are dealing with a device that requires 30 KV (thats thirty thousand) volts to make it light up. Take these as warnings and consult with a technician.
SOURCE: toshiba 50"rear projection hometheater picture shut off on/off light flashing
take the back off and change the fuse
SOURCE: Toshiba 46in DLP No Picture, but good sound.
Hi my name is Eric,
I hope I can help you with your issue ,
Sounds like a bad lamp assembly , search for one online by model# for between $100-$200
easy to install yourself
Hope this helps, if it has solved your issue please click accept
But if you have more questions please respond and I will reply asap
Thanks
Eric
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
SOURCE: I just put a new bulb in my toshiba projection tv
check the covers you removed to change lamp they have safty switches on them the cover is not linning up correctly good luck
