The dispenser board is bad. Had this problem just last month.
My fridge did the same thing. Your high voltage board in the rear of the unit has gone bad. This is a very common problem and maytag is very aware... They well replace at no cost even out of warranty. As well its a very easy fix. Call then and say you know they replace the board at no cost and have then overnight it to you.
I'm having the same problem. However, Maytag says there is no recall and repair is not covered under warranty. Part (board) costs $205 plus shipping. Who did you call to have the board sent to you at no cost?
I am having same issue and plan to call tomorrow. Who did you call?
Ngbaca wrote: My fridge did the same thing. Your high voltage board in the rear of the unit has gone bad. This is a very common problem and maytag is very aware... They well replace at no cost even out of warranty. As well its a very easy fix. Call then and say you know they replace the board at no cost and have then overnight it to you
ryg73,
I called the number inside the fridge. But before i let the representative say much i made these points:
1. the fridge panel is blinking, the ice flap is opening and closing and not it's not keeping cool.
2. I have done research on the internet to which I KNOW this is a VERY common problem for this type of refridgerator in which the high voltage board has gone bad, and from my research I KNOW that maytag is replacing the board at no cost out of warranty.
I was asked to be put on hold and was told it would be sent in 7 days, to which i replied my food was in coolers (lied about that, fridge was keeping marginally cool) and i needed the part overnighted...
call again, maybe I simply talked to a friendly representative.
ryg73,
on a side note, I only had them send me the board. I installed myself, takes about 5 to 10 minutes. Maybe they are denying you because your asking for repairs... try to have the board shipped to you and you can install yourself..
