Question about Bosch HBN 7052 GB Stainless Steel Electric Double Oven
Helpppp!!! an error message on my Bosch double oven. E118. Oven stops but fan continues. Have to turn off breaker and then back on but now it just keeps doing the same thing.
Posted by filadeagrafo on
5 Related Answers
Anonymous
  • 116 Answers
SOURCE: Double oven / convection not working
It is likely that the convection element is burned out and needs to be replaced. If all other functions are working then this is the place to start. Teh back panel inside of the oven can be removed by removing the 4 visible philips screws on it. The element should look smooth and round, if not then it needs to be replaced. Be sure to turn power off to the oven before replacing it. Remove the screws that fasten the element to the back wall and gently pull the element away from the wall an inch or so. the wires will be exposed and can be unclipped from the element do not let them fall inside of the back of the oven or you will have to remove the oven from the wall to get at the back panel. Install the new element in the reverse procedure. If the element looks good then it will have to be tested with a multimeter to verify that it is still good before proceeding to check the selector switch for burn marks.
Posted on Mar 11, 2007
Anonymous
  • 487 Answers
SOURCE: timer clock on bosch double oven
Please follow this link and download the instructions.
Manual
Please rate me as FIXYA
Posted on Apr 29, 2008
aborcass
Ron Coons
  • 2651 Answers
SOURCE: KitchenAid KERA807PSS01 oven won't shut off until breaker thrown
assuming its a stainless stell oven? if so heres the par tyou need its a membrane switch( your cancel button ceased to operate corrrect???not a bad part to install you need to remove a few screws from under control panel itself( perhaps a few on the sides, the front control will lift off and this part is installed from behind the control panel (SHUT THE BREAKER(S))
part number 9756595ES
in the mean time instead of shuttin off the breaker toreset you can simply( requires reading manual ) set your oven to time bake. it will shut off automatically after predetermined time has been obtained.
Posted on Apr 30, 2008
Testimonial: "worked, thanks"
Anonymous
SOURCE: Double Oven says "F0" and beeps continuously
The fault code "F0" is indicating a possible stuck or shorted key pad or oven control board failure.
Determine if the problem is with the key panel or the oven control board by:
1. Pushing Clear/Off pad.
2. Disconnecting the Ribbon Cable Connector from the control board and waiting at least 32 seconds to see if the Code recurs.
If the code recurs, problem is in the control. Replace control.
If the code does not recur the problem is the Key panel and it would need replaced.
This test is normally done by an experienced service technician to avoid any possibility of getting shocked. This has to be done with voltage applied to the wall oven. Extreme caution should be exercised while testing.
I recommend calling a service technician to diagnose and repair your oven.
Posted on Jun 17, 2008
barkencoa
Barry Coates
  • 3463 Answers
SOURCE: bosch convection double oven,ovens won't heat,only broilers work
If it is fan assisted then check the fan element, it is located behind a panel at the rear of the oven compartment.
Plz rate my\solution.
Thanks.
Posted on Dec 17, 2008
A F04 Err is flashing on my Bosch double oven. Please can you tell me what this means?
The only F04 error on a Bosch oven is with the Bosch 5000 Series wall oven. On this model, the problem is with the door latch. Unplug (or turn off at the circuit breaker) the oven. Turn it back on after a few seconds. When the power comes on, the oven should do a self-test of the lock mechanism. If the error persists, you'll need to do some diagnostics to determine if the lock is faulty. The problem could also be with the wiring or the control board didn't register the correct signal from the lock sensor.
Please add a comment with the model number of the wall oven for more assistance and any possible parts lists. You may want to call for service if you aren't comfortable doing this work. You probably need to get the oven out of the wall cavity for some of the diagnostics.
I hope this helps.
Feb 24, 2017 | Bosch Ovens
F31
If the cooling fan is constantly running then means thermal overload probably faulty, it has failed in closed position.
Best to get an engineer to help
warmest regards
Richard the Repairman
Mar 30, 2014 | Bosch HBL 455 Stainless Steel Electric...
Hbl8450 E118 error
E118 indicates a comma error. You could check for loose connector block or plug on ribbon cable. Best course of action is to call a Service Engineer.
Sep 19, 2017 | Bosch Ovens
I have a Bosch double oven and it continues to heat even when I turn it off. I then flip the breaker to turn it off. When I flip the breaker back on a code pops up (VO515 HOO47 ...
Hello there again
I know you rejected the chat and that is all right
Here is the part and what it looks like it may be a different color
Oct 16, 2010 | Ovens
Ge double oven JTP56 top oven heats slow and won't heat up to set temperature. fan comes on after a short time and continues on after oven turned off and never goes off. Oven continues hot even though...
If your electric2_bing.gif oven is not heating then you probably have a bad heating lelement in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Jun 25, 2010 | GE Profile JTP56 Electric Double Oven
We just plugged in our oven and it has E005 Communication error popping on the screen. Any ideas?
1. Turn the clock selector knob to OFF
2. Tweak the oven control by turning the clock selector knob slightly to the left (counter clockwise).
This may stop the popping message.
Thanks
May 31, 2010 | Bosch HBN5650UC Electric Double Oven
Bosch convection double oven,ovens won't heat,only broilers work
Thanks.
Dec 17, 2008 | Bosch Ovens
Fan won't turn off & upper oven work in Manual mode
This sounds like a control panel issue, you may have to replace it, about $300.00
Jul 09, 2017 | Bosch HBN 455 Stainless Steel Electric...
Bosch HBN 7052 GB Stainless Steel Electric Double Oven Logo
2,067 people viewed this question
Top Bosch Ovens Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
Paul Carew
Are you a Bosch Oven Expert? Answer questions, earn points and help others
