Question about JCPenney Gyropter RC Helicopter
Fully charged the choppers battery,the controller has all new batteries,turned on the chopper power switch,turn on te controller power switch and wait till light stops flashing.push on the power controll handle and there is nothing and then all at once the chopper takes off at full power and there is noway to controll the amount of power to the chopper and it stops and falls.other times it does not work at all.
Posted by tj_race on
finefrn
    New Friend:
The light will keep flashing unless you are on the correct channel A B or C and you hit the "Light" button on the front of the unit.
As far as the high speed take offs I suggest identifying which A B or C setting is correct for your copter. In order to do this turn off the RC controller. Set the Selector switch to "A" move the left joystick "throttle" half way up and then turn on the power. Assuming that the copter is still ON it will either fire up or do nothing. If it does nothing try the same sequence with the selector switch set to "B" and try again. If nothing try "C".
Now, as far as the rapid accelleration, I read one online comment that indicated that there is some type of "programming" sequence that the unit learns by pushing the left joystick throttle all the way forward and then back to zero when you start to fly it. So after the first "blast off" set the copter back down or even hold it in you hand by grasping the the landing runners and move the throttle forward until the rotor spin up and it lifts off. In your hand it is easier to keep it from going up too quickly.
Posted on Aug 30, 2011
My Gyro s107g helicopter won't connect to the remote. It just sits there not moving or any lights turning on.
It sounds like the two are not compatable. In other words the freakwinsy of the plane is not the same as the controller. THEY MUST MATCH. You may find the numbers on the back of the controller and where the batteries go in the chopper. If the numbers do not match, take it back to the store, and get one that does. Sorry for the spelling
Jan 13, 2015 | Syma S107G 3CH RC Helicopter RTF w/ Gyro...
Where is the fuse box, why won't my chopper start,no click,no lights,nothing
There are 2 fuses under the seat thats about it google the owners manual its available :)
May 01, 2014 | 2008 Ridley Auto Glide Classic
Bike tries to start with out key on the only to get it to stop is disconect battery
Hi, Rick in order to diagnose the starter circuit you must start with a fully charged battery, 12.5 volts or better and be able to pass a proper load test if necessary. The battery cables and terminals must be clean and tight. The "NEGATIVE" cable is famous for corroding and or breaking inside the harness, check the connectors at both ends. Check your starter relay with a test light for continuity, it could be faulty due to corrosion and sticking in a closed configuration, another claim to fame. Finally, there is the starter solenoid, low battery voltage or faulty battery connections will cause extremely high amperage at the plate and contact shoes and rob the hold in coils of much-needed voltage. In extreme cases, the solenoid plunger plate will literally weld itself to the contact shoes, keeping the circuit closed and thus permanent engagement. Another scenario is unacceptable voltage drop to the starter solenoid from the ignition switch to the starter relay to the starter button, and finally to the solenoid. Remove the green wire from the starter solenoid and hook up the positive lead of your voltmeter to the green wire connector and ground the negative lead. Turn on the ignition switch and depress starter button, the voltage reading should be no more than .5 volt less than the battery voltage. If it is more than .5 volt you need to backtrack that part of the circuit with your volt meter until you find the voltage robbing offender. Next remove the 3 screws that secure the solenoid cover and remove the plunger, dress the plate and the contact shoes of arching residue and make sure the contact shoes are tight and secure. If you have done all of the above, replace the green starter button wire, hook up your voltmeter to the battery and check the voltage drop when you start the engine, anything below 9 volts could indicate a faulty battery and a proper load test should be performed. For more information about your issue, please visit the websites below. Good luck and have a nice day. Starter solenoid autopsy How Nippon Denso starter works
Rebuild starter solenoid
http://fullmanuals.com/brand/bmc-choppers
big mike choppers bmc
Bmc Choppers Motorcycles For Sale
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Mar 03, 2014 | 2009 BMC Choppers Big Daddy
My dragon stinger helicopter wont fly,its only turn around even the throttle stick is totally pull
maybe the battery in the chopper or controler woesn't full, or u should check the chopper if there's any missing pieces. last time mine can't fly and i found out that there's a missing gear. but it's an old one, so i took it apart. good luck:)
Jan 05, 2014 | Toys
I bought a World Tech Toys ZX-A68690 helicopter and I cant get it to work. I charged the battery pack as outlined in the operation manual. I installed the "AA" Duracel batteries in the...
Try turning the controller power on ( before turning on the chopper) and then quickly moving the left throttle stick up to the fastest setting and then immediately back to the slowest speed setting...The flashing should stop. This calibrates the remote throttle range.
Turn on the helicopter and you should be OK
Jun 01, 2011 | Worldtech Devices Toys
My s032 dont seem to hover very well and back and forward dont work very well
are you sure the battery is fully charged the light on the charger
should shine brightly but you might of overcharged it if you have had it on for 90 mins
Dec 26, 2010 | SYMA Toys industrial Syma S032 Ready to...
S032 won't fly higher than 0.5m. and for a few secondes. I bought 2 Syma S032 helicopters whith 3 lipo's. The first 3 a 4 times both choppers flow verywell. I have charged the batterie's so as told in the...
1) Ensure you're fully charging. Indicator light on charging unit should NOT get brighter at all when you unplug the helicopter. If it does, then plug helicopter back into charger until light stays the same when you unplug. Note: If you're charging with a usb charger and are using a laptop or the front side data port on your desktop, these may take several hours to fully charge as they are usb 2.0 and do not carry the full 5 volt dc charge. Use powered usb (3.0) on back of desktop, or get a usb/ac adapter. Normal charge time approximately 1 hour. Go by the light, though.
2) Don't run them dead. As soon as you can no longer maintain altitude, land and turn off helicopter. Fully discharging a Li/Po battery (particularly when it's new) will cripple it's ability to hold a charge, and can ruin them.
hope this helps
r
Nov 01, 2010 | SYMA Toys industrial Syma S032 Ready to...
I Just bought a Syma SO32 R/C helicopter. I charged it up and put new batteries into the remote and for some reason it doesn't work. Both lights on the chopper and remote are shinning but I can't get the...
You need to assign the remote to the copter, turn on copter then remote, push forward on throttle then back, light on remote will stop flashing and remain static, there we go ready to fly have fun great machine.....
Sep 08, 2010 | SYMA Toys industrial Toys
JCPenney Gyropter RC Helicopter Logo
593 people viewed this question
Top JCPenney Toys Experts
Marvin
Marvin
Tom Chichester
ray gallant
Are you a JCPenney Toy Expert? Answer questions, earn points and help others
