Question about Under Armour Impulse Sunglasses
I need a nose piece for my sunglasses - Under Armour Impulse Sunglasses
Posted by joshua_m_whi on
Marvin
    Top Expert:
  • 85,239 Answers
Contact an optical purveyor.
Posted on Oct 30, 2018
Where can I find the grey nose pieces for Tommy Bahama TB6016 001 sunglasses
Direct and free!
Maui Jim sunglasses are warranted to the original purchaser for two years from the date of purchase against any defect in materials and workmanship. Nose pads and temples are free as long as the parts are available. Maui Jim will repair or replace, at their option, any pair of Maui Jim's found to be defective and exclusive of damage caused by improper or unreasonable use.
For repairs visit repairus.mauijim.com. Please complete the form by providing the information needed for your repair.
http://www.tommybahama.com/guest-services/product-information
Apr 28, 2016 | Tommy Bahama Clothing Accessories
Rubber nose piece has split - barely hanging on
Hi.
The part (or the glasses) must be replaced. Cheap repair done with superglue is not a good solution. Please contact Nike customer support using the link below:
Athletic Sport Sunglasses & Technology ' Nike
Mar 27, 2011 | Nike Counter Sunglasses
How to replace the lenses for oakley spike
I did the following... step by step, if you have any questions, please ask. - I placed the sunglasses perpendicular to me. One if the lenses will be close to you, while the other should be farther away.
-I grabbed the farthest lens from your body with both hands. Placing your left had on the left side and your right and on the right side. One had is on the bottom of the lens, while the other is on the top of the lens. It does not matter which hand is on the bottom or top.
-I grabbed the top and bottom of the frame, pulling away from the lens. At the same time I pushed with my fingers (that should be on the inside of the lenses) and pressed the lens out (on the lens closest to the nose pieces). You will hear a very faint "pop" when the lens clears the frame.
-Then slide the lens out by grabbing the part that is out of the frame that is close to the nose piece
-To put the new ones in, position the sunglasses the same way and put the replacement lens in the sunglasses, starting with the edge near the ear pieces.
-Pull the top and bottom of the frame out and push the replacement lens into place.
If you have any questions, please ask. If I can clarify anywhere, let me know.
Good luck.
And once you do this,could you please leave me feedback and vote on my answer?
Thank you very much,
Lori
Mar 17, 2011 | Oakley Spike Sunglasses
I have a pair similar to the EV0253 and the rubber on the nose piece bridge has disintergrated due to interaction with sunscreen. Can I replace the nose bridge piece?
hi
you can certainly replace your nose piece bridge by taking your cool sunglasses to the show room where you brought with the bill they have given you but you should have warrente or you need to pay for it but it wont cost much . or you can vist the site below ,for reparing your sunglass
http://eyewearus.com/pd.asp?prod_id=10918&txt_brand_id=174&cbocat=1
Nov 18, 2010 | Nike EV 0253 Sunglasses
I have a broken nose piece on my Nike sunglasses model sk ace swift...... Where can I send them to be repaired and approximate cost?
i dont think it will cost much pls vist your local show room where you brough it , it may cost 2 to 5 $ approx.
Nov 18, 2010 | Nike EV 0211 Sunglasses
Under Armour Impulse Sunglasses Logo
776 people viewed this question
Top Under Armour Clothing Accessories Experts
Jim Pattison
Tom Chichester
Andrew Taylor
Andrew Taylor
Are you an Under Armour Clothing Accessory Expert? Answer questions, earn points and help others
