The LED Button on the front is on and when it`s pressed the tv doesn`t come on. The light goes green then amber then red and keeps doing this like it`s trying to turn on.
MANUAL PROGRAM CODE SEARCH YOUR XR11 REMOTE TO YOUR TV: 1 – Turn ON the TV you will be using with the XR11 remote. 2 – PRESS AND HOLD the SETUP button (bottom left) on your XR11 remote until the LED status light (top of remote) flashes from Green to Red. 3 – Begin manual TV code search by entering 991 on the XR11 remote. 4 – The LED status light will flash Green 2 times. 5 – Repeatedly press the CHANNEL UP button on the XR11 remote to search through the TV codes. 6 – Keep pressing CHANNEL UP button on the XR11 remote until the TV you are programming turns OFF. 7 – After your TV turns OFF press SETUP. 8 – The LED status light on your remote should flash Green 2 times. 9 – Press the TV Power button on the XR11 remote and if the TV turns ON, your XR11 remote is programmed. Be sure to hold the SETUP button until it flashes Green 2 times after your TV turns OFF.
from the web - 1 Removed the battery 2 Removed the AC power 3 Plugged in the AC power again Note:- At this point the light from flashing amber light to solid green indicating AC Power 4 Plugged in the Battery Note:- Solid green AC power light and Amber charge light
Step 1: Manual Temporary 1. Turn off the printer. And disconnect the printer cable. 2. Press and hold the POWER button, turn on the printer. 3. The indicator (L.E.D.) should be green. 4. Press and release the RESUME button , the indicator (L.E.D.) should be orange. 5. Press and release the RESUME button again, the indicator (L.E.D.) should be green. 6. Release both buttons.
step 2 : Software for Permanant 1. Reconnect the printer cable. 2.Open General Tools software and select (USB PORT) 3.Choose (SET DESTINATION 1) And it should be reset. Sofware Download "After service mode Pls use software for permanent reset Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
With the printer plugged in and powered off, press and hold the Resume/Cancel button, then press and hold the Power button. Do not release the buttons. The LED light should be green to indicate that a function is selectable
While holding the Power button, release the Resume/Cancel button, do not release the Power button
While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and Resume/Cancel buttons. Each time the Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.
When the LED light is green, press the Resume/Cancel button 4 times. Each time the Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.
Press the Power button. The LED lights in green, and the reset is performed. When the operation completes, the printer returns to the menu selection mode automatically
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or
not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to [email protected] if you require further assistance.
Hi Franceso, plz specify Is it powering ON ? Which LED is glowing? These leds are there on the front panel :
1 Power On/Standby button 2 System power LED Green = Power on Amber = System shut down, but power still applied Off = No power
3 Internal health LED (Wave sign in BOX) Green = Normal Amber = System degraded. To identify the component in a degraded state, refer to system board LEDs. Red = System critical. To identify the component in a critical state, refer to system board LEDs. Off = Normal (when in standby mode)
4 External health LED (power supply) Green = Normal Amber = Power redundancy failure Red = Critical power supply failure 5 NIC 1 activity LED Green = Network link Flashing = Network link and activity Off = No link to network. 6 UID LED Blue = Activated Flashing = System remotely managed Off = Deactivated 7 UID button
If it is Internal health led then any internal h/w issue is suspected. If it is external health led then any power supply or power source related issue is suspected. Also
check the status of the server & its IML (Integrated Management
Logs) in ilo (Integrated Lights Out ) if it is configured. (2nd RJ45
port in rear)
Then press the Green Button (Even though it doesn't show as an option)
Then press the Red button for a full reset
Warning: You will lose all data on the Hard Disk!
I did this when mine wouldn't record anything and dumped all my pre-recorded programs.
Worked a treat.
