Question about SanDisk Cruzer Micro 4GB USB 2.0 Flash Drive
I have a sandisk disk on key with a 4gb memory capacity. it currently has NOTHING stored on it yet says i only have 1.45 gb free. how do i clear this up? is there a way i need to format it? thanks! -gita
Posted by gitar613 on
Nuraldeen Mijbil
    New Friend:
  • 83 Answers
Hey gita! Formatting a Flash drive is really simple! Assuming you're using Windows, plug it in your PC and go to My Computer. Right click on the drive and press Format. You can choose either Quick format or normal format(Quick format does it really quickly but it may not yield best results). After that simply press Format and wait for it to finish.
You should have formatted your Flash drive and have your original 4GB of space restored!
Keep in mind that you may have less than 4GB(about 3.8-3.7) This is because formatting writes instructions to the flash drive.
Have fun :)
Posted on Aug 21, 2011
What is a sandisk 4GB
This could be a Hard disk memory,flash memory or sd card memory. 4gb is the capacity. San disk is a type or make.
Nov 16, 2016 | SanDisk Electronics - Others
I am purchase 4 GB memory from mobile store(south ex -2) but after one month problems memory card . so please address srevice center in delhi.
Check how long has the product warranty with the service provider's product or visit this site http://www.sandisk.in/ Regularly that type but not repaired but contacting ScanDisk right through the web.
Good luck
Dec 14, 2010 | SanDisk 4GB microSD High Capacity Memory...
4GB Memory Card and Sony Ericsson C902 Phone
The reason that you are only showing 3806 is because 4Gb is the "UNFORMATTED" capacity of the card, and 3.8Gb is the "FORMATTED" capacity of the card. The .2 or so Gb of space gone is taken by the system information for the card to work w/ the operating system. You can see here for more info, but don't worry there is nothing wrong w/ the card you have.
http://compreviews.about.com/od/storage/a/ActualHDSizes.htm
May 07, 2010 | Cell Phones
Cant format a sandisk 4 gb hc card why?
try formating in the following steps
1. right click on my computer then manage
2. click on disk management
3. right click on the flash drive then format
if the problem still occurs then there is some problem in the memory ic.
Oct 28, 2009 | SanDisk 4GB microSD High Capacity Memory...
Sandisk 4GB card reads full when it's empty.
I would suggest reformatting your disk to your camera. We have had those issues and it has cleared it up. Be sure any pics on your camera have been backed-up as you will loose all pics while reformatting. The key is to reformat your disk to your camera (use the camera's menu to located the reformat disk section)...do not use the computer. Hope it works!
Jun 07, 2009 | SanDisk ULTRA II 4GB Compact Flash Card...
4 GB micro sd and the Sandisk Sansa e250R...
If the 4gb micro SD is a high capacity SD (it will say micro SDHC on it) your player may not be able to read SDHC cards, my sansa can't because it's the 'older version' it will read 2gb and below micro SD cards though (it sucked when I found out because I had just bought a 6gb micro SDHC)
Nov 22, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Cruzer Micro 4GB USB 2.0 Flash Drive Logo
153 people viewed this question
Top SanDisk Electronics - Others Experts
k24674
Marvin
Marvin
ChinthakaJ
ChinthakaJ
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
