Washing Machines Logo
My Zanussi ZWF 1421 washing machine will not use the fabric softener at the end of a cycle. Water goes into the fabric softener drawer but will not drain out. With no softener in the drawer it just fills with water and doesn't drain out.
Posted by davemayes101 on
Anonymous
    Sergeant:
  • 254 Answers
Plz try this link:
http://www.manualsmania.com/model.php?model=2d43f0305358baa1c874c2818d8c4834fade996
hope it helps u out..if not plz revert
Posted on Aug 21, 2011
Dispenser fabric softener slot
Fabric Softener Compartment Full Of Water - White Goods ...
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jul 9, 2013 - The small fabric conditioner compartment in the soap dispenser drawer has a plastic cap or tube at the back for the water to siphon up through. ... Make sure the washer is level front to back as well as side to side. .... If the washing machinehasn't been used since there's always the possibility that the plastic ...
The fabric softener part of my washing machine drawer keeps ...
www.mumsnet.com > Topics > Housekeeping
MumsnetAfter each wash, the fabric conditioner part of the drawer is f. ... The fabric softener part of my washing machine drawer keeps filling with water ... Stopped using thedispenser compartment for fab softener and instead did I separate ... see if that clears it up and also try cleaning behind the drawer in case there is a blockage.
Washing Machine ' Fabric Softener ' Problem ' Won't Empty
Fabric dispenser leaves water in dispenser after wash is done
Jul 9, 2013 - The small fabric conditioner compartment in the soap dispenser drawer has a ... filter at the bottom of my machine is also full of water after every wash my machine is Russell ... My washer flushes out the softener but then leaves the water at the end. ... When the wash cycle has finished the fabric conditioner ...
Fabric softener drawer water residue after washer completed cycle
This is probably due to a build up of residue of softener. Remove the drawer, strip the bits off, and clean with a toothbrush. Then replace, and this should solve the problem.
Why does water softener drawer still have water in it at the end of cycle
It is clear water right? The filler tube flushes as it empties and it always has a small amount of flush water in it.
2answers
Zanussi FLE1216w Repair Manual
Hi, my zanussi fle1216w is skipping the fabric softener stage of the cycle. I've cleaned the dispensing drawer and the surrounding areas, even put on a boil wash in case somethihg was gunge up or visits the Zanussi Owners Manual.
My washing machine fabric drawer is blocked have cleaned complete drawer but still fabric softner is in the drawer at the end of cycle .
Pull the little 'hat' off it's post in the fabric softener compartment. Clean off any softener residue and return.
Will not take softner?
clean the dispenser drawer, then using thin pipe cleaner clean the two outlets that fall over the softner drawer, its easier if water is flowing from them, to do this switch on the servvice cycle (no clothes in the machine) as u swtich it on, hold the start pause and skip button down and then press the fabric button repeatedly until the water comes through the outlets over the softener compartment.
to exit service cycle u must swtich the machine on and off twice
Fabric softener tray doesn't drain
what u need to do is take your soap drawer out take it to the sink now take your fabric softener draw out the pipe that is fixed into the main drawer will need cleaning out has this will be slightly blocked with thick softener or powder once all the main drawer is cleaned do the same with the softener drawer put it back together and it should stop it from blocking up again m8
The fabric softener doesn't go in...
The detergent dispenser is located above the detergent drawer. A water pipe is connected to it and water entrance and distribution to drawer's cells (following the programmed cycle)are done by a lever's movement (part of the dispenser). The lever movement is controlled by two solenoids that received their power from the timer. By opening upper machine's cover you will have an access to the dispenser. Disconnect the power cable from the machine before moving to next test !!!! Look first that they are not any disconnected wires. Move manually dispenser's lever and see if water running to all cells (depend on your movement). In case it doesn't work properly remove the unit from the machine and try to clean it (I hope it will help, otherwise you should replace the unit). In case it works properly (manually) - you should test by a multi-tester solenoid's resistance. the one that doesn't have a resistance measurement should be replaced. Good luck !!
Top Washing Machines Experts
Marvin
Marvin
W.L.
