I had went swimming and had not realized that I had my player in my pocket. About a half hour later when I got out I found the player in my pocket. I popped a side open as far as possible and placed a fan near it for days, checked for water droplets after that and found none. I attemted to turn it on and it didn't even try. I thought maybe I just ended the life of the battery. I connected it to my computer by cord and it didn't turn on nor did the computer recognize it. Help please.
SOURCE: Player cannot get connected to computer-Philips GoGear SA3115
Install and run the Philips Device Manager software from the product CD.
Select the Repair / Restore option and follow the on-screen prompts.
This will format the player and repair the firmware.
SOURCE: sa177/00 "recovery mode" problems in Philips Firmware Manager
Try to defrag the drive .... is not workd thn format it manually frm PC n reset the set hopefully it will get back to normal. i did this with mine go gear n its fine now.
SOURCE: philips gogear mp3 stuck on gogear screen
try putting it into recovery mode by holding the volume up while plugging it into the pc this might at least get the pc to see it also try it with a diffrent cable
SOURCE: Philips 8gb Gogear SA3085/02 -"DRM License not available"appears
In your Windows media Player go into tools and select options. Select rip music and untick copy protect music. The music you have in WMP wont work. you will have to put them in again after you made the changes. Hope this helps
SOURCE: I have Phillips GoGear Vibe 8GB SA2VBE08K It is
Use a pen tip or other sharp object to insert the RESET hole on the side of the player.
Here is a page which shows you how to transfer music over to your new Phillips Media Player. Windows Media Player sync is specific to Windows products. Do NOT use this to transfer music to your Phillips media player. Use the software supplied by the manufacturer.
If this solves your problem, please come back and rate our solution. Thank you.
Testimonial: "Great! That worked. Thanks so much!"
