SOURCE: we have a dreammaker spa, how do we drain it? the
The Fantasy has a drain located in the toekick of the spa. You have to first remove the drain cap, attach a hose if you wish, spin the outer black ring counter clockwise to start the water flow, then pull the outer ring out away from the tub to increase the drain to full flow.
I understand that a screw driver is often needed to pull the outer ring out to achieve full flow. Therefore, I suggest another method. Take a garden hose and place it in front of the jet while the spa jets are on. This will force water flow thru the hose and prime the hose. Once you see water running from the other end of the hose, drop the hose in front of the spa jet into the footwell and as long as the loose end is lower than the end in the footwell, a siphon will drain the spa as fast as the spa drain will. Remember to turn off electric to the spa once you have established a siphon. You may have to bucket the last bit of water in the footwell. Goodluck.
SOURCE: My dreammaker spa has power and lights but the
Sounds like the pump is jammed or the motor bearings are frozen. If you can take it apart, try the pump first. The bearings on modern motors are pretty reliable. Get everything cleaned and lubed and put it back together. Good luck...Lee
SOURCE: over heating
Try turning the power off and back on again.
If this doesn't solve the problem you have further issues.
Regards,
Ian.
http://hottub.synthasite.com
SOURCE: I have a fantasy dreammaker spa that plugs into a
This is a GFCI and will trip at the least bit of water at the plug or at the wiring inside the spa controls. Just go through the system and make sure all is dry. Use a hair dryer in the outlet and on the controls and wiring. If you still have problems you may need to call an electrician.
SOURCE: Dream Maker spa GFCI plug was all corroded. I cut
Did you make sure you observed the correct polaity on the cord? The white wire should go to the silver screw on the cord cap. The black wire should go to the gold terminal (brass) and the Green wire should go to the Green screw. If the plug was corroded, is it possible that the GFCI is also corroded? They aren't that expensive and you could replace the GFCI yourself if you're sure you can locate the circuit breaker and turn it off.
