Question about Sony Handycam DCR-TRV330 Digital Camcorder
I have a Sony digital video camera recorder TRV330. The error message that is flashing is C: 31:42. How do I fix it?
Posted by cplp18 on
Anonymous
    Genius:
  • 1,812 Answers
Error code 31:42 indicates a problem in the cameras tape drive system. This can be caused by several problems including the transmission gear in the tape mechanism not engaging properly, a dislodged pinch roller or a defective clutch in the take-up spool and will require disassembling the camera to repair. This can usually be done fairly inexpensively. However, it's not a really user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Posted on Aug 21, 2011
Transfer video from tape to memory stick to put on computer using a sony handycam recorder dvr-trv330?
Yes you should be able to get a USB to Firewire cable for about £10 to get your movies over to your PC or Laptop computer, that is what I am doing now, then to edit my films and burn to a DVD to post to mates.
1helpful
When i try to use my camcorder there's a flashing light with the eject symbol and it wont record or let me use the video
Flashing eject sign error appears when camcorder got problem in its mechanism, please put another tape and check.
Remove battery from camcorder for couple of minutes, put battery back and try.
Also observe does tape reels turns reverse and forward when tape loaded in mechanism.
If problem still exist, qualified camera tech will fix it because it is not user level repair.
1helpful
I cannot download from camcorder dcr-trv330 to pc.. help It is a Sony Digital 8. I downloaded the USb driver but pc does not recognize it. Is ther any other way to download tapes to PC?or make a DVD
If your PC has DV link port, connect camera via DV link and transfer movie files in computer.
Other way is to hook camera with DVD recorder and burn DVD.
Thanks.
1helpful
My camera wont turn on
dear
check your charger is it supplying the same rated voltage forless .. try to change n then tell me
Vista Driver for Sony TRV330
No driver required. Plug the supplied cable into the computer firewire port and the Sony "i-Link" port on the TRV-330 and turn on the TRV-330 in VCR mode. Works in XP and Vista out of the box.
Flashing error message C:31:23
Hi Jazzy,
Please see the detail below for the said error codes C31:23.
According to the symptom and self diagnostic system the problem is in mechanical section (tape loading section) Therefore camera just need mechanical adjustment and will work fine again. This problem aries when the insertion of the cassette is improper or forced insertion.
Thanks for using fixya.
Sony DCR TRV330 Error message C:31:22
This is a failure of a motor to move inside the camera. There are a number of causes of this problem. The tape will be ejected to prevent the tape from getting damaged. This is usually the head/drum assembly that is not moving. This is not a repair that should be attempted by an inexperienced individual. Please bring this to a service center for repair.
Dan
Sony Handycam DCR-TRV330 Digital-8 won't calibrate tapes to be able to view
hi there. i just actually had this problem right now. and heres how i fixed it :) it had the error so i took out the tape left it ejected for about 5 seconds. then put the tape back. it read for a little then errored again so it was close. next what i did is plugged the camera in (last time this error happened i plugged in the power and it fixed it) still no fix so i took off the battery waited 5 seconds then put it back on. after that i ejected the tape again and re put it in and it worked! you could try anyone of those things. and usually they work for me. maybe it has something to do with the cameras being old.
C:32:30 error flashes on screen
It was due to moisture condensation. I left the cassette compartment open and remove the battery for one hour approximately. then fixed the battery again and tried and it worked.
Sony Handycam DCR-TRV330 Digital Camcorder Logo
Top Sony Video Cameras Experts
Ekse
Nasir Muhammad
Nasir Muhammad
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
