Question about Haier HVFM30A Wine Cooler
My Haier Wine Cooler HVFM30A the compressor or motor over heated and stop working. Can I replace it?
Posted by d_hartmann on
TickMagnet
    Scholar:
    New Friend:
  • 68 Answers
A new compressor for that unit from Sears parts direct costs $206.
The unit itself is worth around $233 and is no longer in production.
After you pay someone to replace the compressor you'll have spent way more than it is worth.
Your best bet is to get a new wine cooler.
TickMagnet
Posted on Aug 20, 2011
Compressor seems bad
HI sally.well wine coolers r not rocket science.your local engineer should be able to at least diagnose the problem...lets c if u can do it ok?(still getting power )u mean light comes on or u mean it runs but dont get cold?well haier is not the best but if it's done 7 years is not bad:).ok...1-check if it makes any noise or is completely quiet.if no sound feel the motor (compressor).hot or cold.if cold it could be the thermostat or motor.if hot running or not it could be refrigerant or motor.needs visual.hope this helps.ALI
Jul 09, 2012 | Haier HVFM20ABB Wine Cooler
I have a Haier model BC112G that stopped working. I unplugged it overnight and it still won't work. It just makes a clicking sound once in a while. Any Ideas? Wayne
Sounds like you compressor won't come on, check you warranty status before you call anyone. This repair can cost more than the unit did. The clicking noise is the overload on the compressor witch will happen if the relay fails (rare on this unit) or the compressor locked up. Either way, check warranty status on you unit before you call anyone, maybe cheaper to replace unit.... I hope this helped..
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Jul 11, 2011 | Haier BC112G Wine Cooler
Cooler constantly runs
It sounds like it could be a thermostat problem. If it is a faulty thermostat, you will have to replace it as it will burn out the motor (compressor).
http://www.google.ca/search?hl=en&safe=off&client=firefox-a&hs=DMy&rls=org.mozilla%3Aen-US%3Aofficial&q=Haier+BC112G+Wine+Cooler+thermostat&aq=f&aqi=&aql=&oq=
May 27, 2011 | Haier BC112G Wine Cooler
It just stopt cooling ([email protected])
Turn the temperature dial to the lowest temperature setting. Wait 24 hours for the wine cooler to reach the desired temperature. Also, turn the wine cooler off and inspect the fan. If the fan if it's running or not.
Lastly, check the compressor.
These are the areas that could make your wine cooler stop cooling; the temperatue settings (Thermostat), then Fan and the compressor.
Check these three areas and let me have a feed back.
Bye for now.
Mar 04, 2011 | Haier BC112G Wine Cooler
Haier HVTB18DaBB Wine Cooler has stopped working. It was working yesterday and today it isn't.
check if it still has power, if it does check the back of the cooler to see if the fans have stopped running, you might need new fans.
Oct 03, 2010 | Haier HVTS18DABB Wine Cooler
We got a Haier 42 wine cooler. The motor doesn't run.
This is something you can not fix yourself. Remember it might cost as much as a new wine cooler to repair. As for free estimate on repait. That way if it cost to much your not out anything. Rus
Jun 17, 2009 | Haier BC112G Wine Cooler
Making clicking sound motor gets hot but not cooling
Your PTC relay on the compressor is bad needs to be replaced.
First be sure to unplug cooler. Remove the cardboard cover that covers most backs of the units. Remove the plastic cover that is on the side of compressor. It is held on with a metal clip. Now you should be able to see the relay pry the relay straight off. note the wiring and position of relay. Only three prongs on compressor. Go to a parts house for appliance's and with your make and model number should be able to get a new one. Let me know if you need any more help. ken
May 03, 2009 | Haier HVFM20ABB Wine Cooler
Haier wine cooler freezes the wine.
You may find that the thermostat is not working. Try to turn the thermostat to the warmest setting, the compressor should switch off within two hours, if not change the thermostat.
Mar 09, 2009 | Haier BC112G Wine Cooler
Wine Cooler Temperture Regulation
Replace the circuit board . Please Rate This !!!! Thank You!!
Jun 08, 2008 | Haier HVF042 Wine Cooler
Haier BC112G Wine Cooler Beeping and overcooling
That thing that's beeping...it is the circuit board. It is telling you that it wants a new cousin to live in your house. Replace it.
Oct 28, 2007 | Haier BC112G Wine Cooler
Haier HVFM30A Wine Cooler Logo
245 people viewed this question
Top Haier Refrigerators Experts
Marvin
Marvin
Vernon Taylor
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
