Televison & Video Logo
Posted on Jul 10, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hitachi big screen model CU5003D purchased 9/1991
This has been an excellent TV , no problems for 17 years , the picture is still great , however the TV will not turn on. It only clicks when the on/off switch is pressed. I assume it has something to do with the power on / off switch.
Do this problem sound familiar and should I have it fixed , what would the approximate repair cost be. I only ask since it was still working great.
Harold
  • jimmyw3boys Sep 07, 2008
    I have a Hitachi SP43H purchased in 2000. This TV has been trouble free until a few weeks ago, the unit will shut off and the red power light will blink and make a pulsing sound. If you turn it off, the lights and sound stop. After several minutes, you can turn it on and it may play for several more hours before shuting off again. Some days it may only shut off once, other days numerous times. PLEASE HELP, I have a 18 month old boy that is not happy!!!!
Paul Bade
Level 3:
  • Master 1,818 Answers
  • Posted on Jul 10, 2017
Paul Bade
Master
Level 3:
Answers
1818
Questions
Helped
574138
Points
5816
Most likely the power supply has failed or has detected a fault in another circuit. (The CRT-type rear projection TVs were prone to convergence amplifier failure, which could blow internal fuses; you may have a bad convergence amp that doesn't quite blow its fuse but still overloads the power supply. Usually they go out completely; the TV still runs, but one or more colors in the picture distort into a bow-tie shape.)
The TV was obsolete 15 years ago, so it would probably be impossible to get a replacement modules. A technician may be able to repair the TV by tracking down and replacing the bad component, but you would likely pay well over $100 in bench charges.
You can get a 50" LCD TV that uses less power and takes up much less space for $300-$600, has nearly twice as sharp a picture, and works with modern digital TV inputs.
1 Related Answer
Anonymous
  • 113 Answers
  • Posted on Feb 28, 2008
SOURCE: to fix or not?? 1990 Hitachi big screen
Sorry the answer is no. If the rolling pic was the only problem you had then yes throw a new signal board in and move on. In this case your picture not being as sharp as it used to be will also be tubes going bad..18 years not a bad run on three tubes that run extremely warm. Have fun on your upgrade to lcd or dlp proojection this will cost less than the fix of your tv.
Josh
Bright blue concave archs accross top of the screen with some yellowish ghosts on any lettering accross bottom of screen. This is a hitachi model 53fdx01b rear projection tv that normally has an excellant...
Sounds like a convergence failure, here is a tutorial I made:
http://www.fixya.com/support/r5001731-convergence_diagnosing_convergence
Let me know if I can be of further assistance.
Age of tv?
I purchased mine from Circuit city back in spring of 2002 as a display model that they were no longer selling. So I would assume 2001 which would be almost 8 years old. Excellent tv!
To fix or not?? 1990 Hitachi big screen
Josh
Hitachi Projection on/off problem
Tell me what it does when you try turning it on...accordianman
HITACHI Projection TV 53FDX20B having too much red color
my hitachi projection big screen tv 57SWX20B has a draping affect across top of screen why?
Picture quality
i have a similar problem, when watching football the picture is terrible,but when im watchin ordinary tv its great
Picture reduced to a horizontal line across center
sounds like the vertical, more info ctechnicians.com
4answers
HITACHI PROJECTION TV
veecorr i had the same problem it cost me $300 to fix i only fixed it because my buddy repaired it for me he told me that these tv's are a very good make so that's why i fixed it it's like new again.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
