Question about LG 47LG50 47 in. LCD HDTV
Neither of my remotes (1 came with the television when I bought it and the other is a remote for my cable box that is programmed for the TV too) are working on my 47LG50 television But the remotes have new batteries and I have tried resetting the television by unplugging it for 10 minutes .
  • Anonymous Aug 20, 2011
    The cable remote is working on the cable box. The buttons on the TV itself are working to control the television. I verified the infrared light is working on both remotes and I cleaned them as well. The remotes are still not working the television which was the original problem.
Chi Chu
  • LG Master
  • 8,457 Answers
Tries take both remotes controls pushes all the funsctions butons one by one on the front of a turn on Digital Camera,see if u will able to see all the INFER RED signal white light will flashing on the Digital Camera viewing screen.To make sure both the remotes are working and all the buttons are have INFER RED light signal out.Tries pushes all the tv manual buttons on the tv side too see if it is funsctioning too.If all these work testing work,than take some rubbing alchahol put on a rag clean the INFER RED sensors signals on the tv an the cable box by the tv power light LED indications lights.Tries these steps,make sure tv manual control tv side panel work and both remotes works and clean both INFER RED sensors on cable box and tv make it work better.Unplug the cable box for an hour for it to reboot and updating it softwares.Replug the cable box and now tries the tv remote or cable remote again,should functions now.
Posted on Aug 20, 2011
Testimonial: "Totally rocked - I couldn't find the answer anywhere else online and I got the information right here after a few questions and a little digging."
  • 2 more comments
  • Chi Chu Aug 23, 2011
    Check the back of the tv have any ear phone socket? Yes take ear phone plug jack plug it into the ear phone socket.Plug it in and take out of the ear phone socket plug a couple time it will help the remote to work again,because this ear phone socket mini circuit they're link to the remote to finsction too.
  • Anonymous Aug 24, 2011
    That was perfect! Thank you so much... it's working great now. I really appreciate the feedback, chu3505.
  • Chi Chu Aug 24, 2011
    vote four thumbs for a rating helping u solve the problems.
  • grandmasterc Aug 29, 2011
    I had the same problem with my LG plasma 42inch tv and solved it thanks to your advice. Thank u very much.
Bud Martin
  • 11,361 Answers
Please read here (look at number 2):
http://www.fixya.com/support/r9057406-lg_lcd_tv_remote_problem
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: http://interliquidparts.com/
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Posted on Aug 22, 2011
Why won't television turn on with remote control?
Check the remote control for its infrared emission. Check it with fresh batteries. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
http://electrohelponline.blogspot.com/
Sep 12, 2014 | Sanyo DP26640 LCD TV
Just bought a vizio e502ar 50" LCD. I programmed it with the scientific atlanta remote control UR5L-8700L. For some reason it will control de TV perfectly but stops controling the cable box. If I turn
I hate to say it but use two remotes--original for the Vizio and the box remote for the box---some kind of conflict here---you can also try to unplug things from power for while and repower to see if a reboot will help or not.
Dec 03, 2012 | Televison & Video
Programming Cox Cable Box Remote to Vizio TV
using a cox cable remote. cant program to work cable and tv functions at the same time. please help?
Jun 02, 2009 | Vizio VX37L Television
Need code for motorola cable box with a insignia remote
Assuming you have the DRC800 remote:
Codes are 0467 or 1376
You can EASILY program the remote without a key code:
1. Press the "cbl" button
2. Press and hold "setup" button Until red light blinks twice
3. Press 9-9-1
4. Press power button
5. Press chanel up repeadedly until your cable box shuts off
6. Press "setup" button again
That should be all there is to it. You can do the same thing for TV,VCR/DVD,Audio, whatever
It's easier than it looks.
Here is a website with more info if you need it:
http://www.eastlink.ca/cable/support/documents/DRC800_User_Guide.pdf
Jan 17, 2009 | Insignia LCDTV26 26 in. Television
Need remote codes for emerson lc320em9 so can program cable remot
If you only wish to power the TV off/on with the remote, there is an alternative. Plug the TV into the outlet on the back of the Comcast box. In the Setup Menu for the Comcast box there is an option to make the outlet switched or unswitched. Select SWITCHED then the TV will turn on/off with the Comcast box. The
LC320em9 will maintain the previously selected input.
Jan 16, 2009 | Televison & Video
Programming the Acquos Remote
There is a code out there to try.  The code would be 47.  Just follow the steps in your manual on how to program this box and you should be able to go from there. Can't garantee that it will work as that code came out with the newer tv but it should work.
Nov 08, 2008 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
Need original remote for tv
Okay, after searching for a bit, I found a site that sells one for $19.95.
Click here.
It says that this replacement is exact function of original.
May 24, 2008 | Symphonic ST419E TV
Cable connection
some older tv's only go up to so many channels.you may not even need a remote to set up cable tv. if you are going to use a cable box on this tv, put the tv on channel 3.if not, look in front of the tv for a little door. behind it maybe knobs or buttons that can program the channels 1 at a time [+= add - = erase. there also maybe a switch for different cable types [hrc,std, etc]
hope this helps
wg
Feb 02, 2008 | Televison & Video
Want to use cable remote 4 tv as well
reade the booklet that came with the cable box to get the program #'s for the remote to control you tv as well
Dec 25, 2007 | Durabrand DWT1905 TV
Remote Sensor on TV Doesn't Work and Can't Manually Adjust Menu
i bought tv ,just week ago and tv sensor on tv want wwork, that why we cant use remote.
Aug 19, 2006 | Sony FD Trinitron WEGA KV-20FV300 20" TV
LG 47LG50 47 in. LCD HDTV Logo
368 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
