These filters can usually be removed and cleaned by carefully sliding it upwards. Some units they just unclip, pop off with a sligh force. However removing the filter will only expose the evaporator, it is MUCH recommended to remove the entire back cover of the unit to gain access to the condenser and clean both of the radiators.
SOURCE: Windchaser air conditioner alarm light is on and it won't turn on
look at the water shut of float, as when the bottom of unit fills with water nor the bottom water float shut of gets stuck in the up position of the toggle relay itself get falty this will cause the proble you discribe
SOURCE: Portable Air conditioner is not starting and then stopping.
Empty the water out of the collection pan? This will shut the unit down to keep it from ruining your floors. Hope this helps 2rns4u <*{{{>(
SOURCE: Windchaser PACRWC-HP Portable Air Drainage Issue
obviously condensate sensor is fault. You may need to replace it. Yes it okey to turn it on now.
SOURCE: I have a Windchaser Portable
You can get all kind of Windchaser AC manuals here: http://manuals-market.com/search.php?cmarque=PERFORMANCE%20TEKNIQUE&modele=ICBM%20779.
After clicking this link you will be forwarded to a page contains a form. You need to fill up that form. Most of them are pre-filled. You need to write "Windchaser" in Brand box and model number in "model number" box.
Please don't forget to mention "Air Condotioner" in the "description box". Finally accept their "terms and condition" and click on "search" tab.
Hope this will help you. Good Luck.
