The received fax is clean but when you send one out it has a black streak on it. Cool! So far so good. Makes sense because for sending, the fax scans the original document and parts of the scanning area could be dirty and so on. Therefore a black streak may appear. The same black streak would also appear when you make a copy, because the original document must also be scanned. Logical!
However for receiving faxes, the machine uses the internal memory and the print engine only, and the same applies to printing the transaction report, which comes from inside via the print engine. The scanner has no rol in either situation.
there should be a black thin wire with a button to move over that wire that cleans it. I would also take out the toner and make sure there is no stains there
I was going crazy! Had a tech come in and look at the machine - needless to say he did NOTHING! A friend came over and was trying different things. It was that the "rack" that the toner cartridges sit in was not fully seated - once he pushed down a little and heard it "click" I had no more black streaks. AMAZING
This is the test to determine toner or fuser issue. Print a test page When you hear the paper feed into the machine open the top or front to stop the machine Remove the toner cart. You should be able to see the page with printing on it. (This is before the page hits the fuser) If you can see the defect on the page the problem is most likely the toner cartridge but NOT the fuser. If the page is clean the problem is most likely the fuser. Hope this helps
I've refilled the toner cartridges a few times now and never had a problem with vertical streaks until recently. I refilled both the cyan and magenta and when I ran the test page I had dark vertical streaks on both sides. I fiddled around cleaning things, running cleaning paper through, changing reset resistors but to no avail so eventually decided to buy a replacement refurbished cyan cartridge since the streaks looked mainly blue and bingo... well almost now I just have very light magenta streaks. The issue is obvious when I compared the old and new cartridge, the replacement toner is a much duller cyan and is of the wrong consistency since once it's been in the printer everything gets covered in it which is why I think it causes the banding to occur. I'm just trying to work out now whether to try refilling the magenta again (v. messy) or just go for another refurbished cartridge (£34).
copystar 1510/1810
