SOURCE: AV1 / AV2 Connections don't work
No picture or dark picture
Check R516 (56Kohms, 0.5w) or R517 (27Kohms, 0.25w) for high
Will not come out of standby, no picture
If at power on voltage on pin 37 of the micro drops low then reverts to 5v suspect memory chip ICA07 (Toshiba 23319016)
No picture No sound
Faulty IC TDA6107q on crt board
No picture on e-e, I.F output ok
This was due to switching chip IC3901 (M51292FP) on the scart panel
SOURCE: I have an external DVD Recorder / Player attached
I have a LG tv set. When i press the tv/av button on the remote my tv shows av1, av2 earlier but now it is showing only av. So i am unable to watch my dvd player. Need help.
SOURCE: When trying to switch from AV1 to AV2 with the
The Red, White & Yellow connectors are your composite inputs usually classed as AV3 or component. The AV1 input is a Scart connection, if you have a scart cable, connect this as your AV source & the TV will switch from AV to component.
SOURCE: AV1 AV2 hook up
you should find them by seeing if you can find ports that are colored yellow, red and white
SOURCE: it's not really a problem.
As long as the N64 uses a composite cable (red and white for audio, yellow for video), you can use either connection.
AV1 connections are on the back
AV2 connections are on the side
Manual link:
http://www.lg.com/us/support/product/support-product-profile.jsp?customerModelCode=42LC2D&matchedModelCode=NOT_MATCHED&searchEngineModelCode=42LC2D&targetPage=support-product-profile&initialTab=documents#
Testimonial: "ahh, thank you so much!"
