Question about Schlage BE365-CAM BE365CAM505 Lifetime Polished Brass Electronic Security K
Lost the instructions How do I reset the entry code? Where can I find the lock registration #?
How can I program my electronic keypad lock when the instructions with the programming code have been lost?
The back plate of the keypad side of the lock on the exterior of the door has a sticker which includes the serial number, six digit programming code and two pre-programmed four digit user codes. The lock must be disassembled to a point the exterior of the lock can be pulled away from the door and the information on the sticker made note of.
This number is the programming code referenced in the information for changing the entry code.
This link will take you to the page that you need to get started:
http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx
Then scroll down to this heading on that page:
Electronic Security-Keypad Deadbolt BE365
There's a wealth of info under that heading. You will be able to see a PDF file of the original print instructions, as well as a video of how to install the lock. This installation video (second item down) will be useful to allow you to disassemble it and view the sticker. This is also a great time to change the 9-volt battery! Batteries should be replace about every three years.
The seventh item under that same header is a video which walks you through how to reprogram the keypad to your new code, using that programming code that you found on the backside of the keypad.
A note about the PDF files: If you cannot view a given file, you need to first install Adobe reader. You can get the free download from here:
http://get.adobe.com/reader/
Good luck--and please provide feedback if this helps!
Posted on Aug 20, 2011
Jan 13, 2013 | Schlage FE595 Plymouth Electronic Keypad...
Jul 06, 2011 | Schlage FE595VCAM716ACC Camelot Keypad...
May 22, 2011 | Itouchless Bm003l Bio-matic Fingerprint...
Apr 01, 2011 | Simplex Kaba Ilco Unican L1000 keyless...
Mar 01, 2011 | Lexus RX 300 Cars & Trucks
Dec 28, 2010 | Schlage Locks & Locksmithing
Sep 07, 2010 | Directed Dei Valet 561r Remote...
May 16, 2009 | Schlage Locks & Locksmithing
Mar 07, 2008 | Kwikset Professional Door Lock...
563 people viewed this question
Reset code lost instructions to reset it
