Question about GrandView Elegant Pull Down Screen Projector Screen
I have toshiba p621dls with broken projection screen. Does anyone knows where can I buy this screen? thanks..
Posted by sherwin_nola on
Juvy Bas
    New Friend:
Does anyone knows where I can buy the Color Wheel for Toshiba P621DLS?
Posted on Aug 20, 2016
Noel Jucutan
  • 998 Answers
Sir try to check this link http://www.interliquidparts.com/ good day and best regards.
Posted on Aug 20, 2011
I have Toshiba Theaterview 50A60 projection TV ( built April, 2001 ) with a broken front screen. Anyone know where to find one??
http://www.partstore.com/ give them a call. If they don't have it, the can tell you where to get it or maybe order it special for you. Good luck!
Oct 09, 2010 | Toshiba 50A60 50" Rear Projection...
Broken screen
You can buy the screen from shopjimmy.com if they have any in stock. Usually you will not find the screen easily and even if you find, it is expensive. Its better to buy the new TV instead of investing money and wasting time. Replacing screen is also time consuming and not easy.
Apr 28, 2010 | Toshiba 65HM167 65" Projection Television
Broken Screens the inside one and the outsid one
Toshiba or any Toshiba parts distributor. Do a goole search. The outer is called the Lenticular screen and the inner is the fresnal screen. Not hard to change.
Nov 17, 2009 | Toshiba TheaterWide 52HM84 52" Rear...
Need to replace all three screen sheets, anyone know where to get cheap used parts? Toshiba is not making them anymore.
Hi, thank you for visit fix ya.
Do you follow the best way, because new screens, is too expense.
I recommended try to find in any shop tv repair in your area.
If can't find, let me know I have couple screens, Maybe I can send to you.
thank you
Jul 29, 2009 | Toshiba 57H81 57" Rear Projection...
Broken Screen
the only fast solution is to go to an authorized TOSHIBA dealer repair shop and have it order it , warning the screen is expensive as I found out when I needed one too ( i own a 55" TOSHIBA ) it could cost around $200.00 up to $400.00. hope this info helps
Apr 25, 2008 | Toshiba TP50H50 50" Rear Projection...
Toshiba TP61G60
Hi.
I have toshiba TP61G60 projection TV and accidently broke the 61" grey plastic screen which is covering a glass screen.
Does anyone know wher to buy that screen?
Apr 15, 2008 | Televison & Video
Screen Hinges broken
Did you call Toshiba?
Mar 09, 2008 | Computers & Internet
SCREEN BROKEN
Did you ever find a screen for your Toshiba?? I need one also. Thanks
Jan 02, 2008 | Toshiba TP55G60 55" Rear Projection...
Cracked screen
rmaura,
My Toshiba TE55T11 also has a broken screen. I contacted the Toshiba hot line in Australia and they said that they don't make screens for this TV anymore. so i just got a new Toshiba 72CM9UA.
I hope this info is useful!
Oct 12, 2007 | Toshiba TE55T11 55" Rear Projection...
Toshiba TZ50V51
I have same problem my screen is cracked and cant find a place for parts.
If someone replies they will answer to postings.
Thanks
Shag
Sep 09, 2007 | Toshiba TZ50V51 50" Rear Projection...
GrandView Elegant Pull Down Screen Projector Screen Logo
111 people viewed this question
Top GrandView Office Equipment & Supplies Experts
Marvin
Marvin
Are you a GrandView Office Equipment and Supply Expert? Answer questions, earn points and help others
