Washing Machines Logo
Maytag front loader 2000 series code LF followed instructions in manual and has no power. Outlet works
Anonymous
    Master:
  • 577 Answers
Hi, is this a new washing machine? If not, then these Maytag front loading washing machines use a paraffin locking switch in the front panel to lock the door during operation. Now, if the switch has gone south and trip the the lock switch without locking the door. Then the washing machine want turn on.
What is a parfin locking switch work is a small container with paraffin (wax) in it with a heater. When the washing machine is turn on. The control board indicate that the machine is in operation and a small amount of current is applied to the paraffin switch to the heating element. This make the parfin to expand trip the locking mechanism and locking door during operation. Keep the door lock from accidental openings. It will take about 4 minute after the washing machine has quite it running operation to open the front loader door. The paraffin needs to cool down to release the locking mechanism. stewbison
Posted on Aug 20, 2011
  • Anonymous Aug 20, 2011
    This does not answer my question at all The machine is very new, I can open the door and I had an LF code on it which means I have low water flow. Does that mean that I am not getting enough water going through and perhaps a clog. The code no longer appears as there is no power light on and wont work when the power button is pressed but the outlet works fine,.
    Low water indicates the control boards isn't letting enough water in. This is control by the load setting in the microprocessor. Heavy load will give the maximum amount of water. Now, the maximum amount of is set by the Washing Machine confederation. To conserve water. I think here in the US it set at 9 gals of water max. Dishwasher have there own water setting.
    There could be a couple of thing wrong here. One, the water level indicator can be faulty showing low water metering. The electronic timer could be malfunction only letting just some water and not what it should be indicating on water level. Also the water inlet for the cold and hot water is control by a couple sensor one is the how heavy is the load and the limit is set to 9 gals of water and no more. Smaller the load the less water is need, more load, more water
    If you have a window in the door of this Maytag washing machine. Put the maxium load in the machine and before it start it cycle. Take a look at where the water level is on the window--for a heavy load the water level will be less that half on door window. Remove the hoses from the back of the washing machine. Once they are remove there will be a screen on each hot and cold solenoid inlets. see if they are plug. Also, on the other end of the hoses is another screen in the noses. Check these screens.
    You also mentioned that there was no power. Power for what? Does this Maytag washing machine working or not. stewbsion
How do you run diagnostics n Maytag epic front loader?
How to Troubleshoot a Maytag Epic Washer Front Loader Tip Call Maytag for service if any of these procedures doesn't clear the code on the washer display.
Warning Maytag makes several models in the Epic series and operating instructions vary. For model-specific troubleshooting instructions defer to the user manual that came with your machine or contact Maytag support.
Each model in the Maytag's Epic automatic clothes washer series has a computerized processing unit that displays error codes on a digital screen when something goes wrong with the washer. These codes help Maytag service technicians diagnose the unit. If you know the codes, you can troubleshoot the problem yourself, rather than request a service call, possibly fixing the issue yourself and saving you some money in the process.
Long Fill (LF) or Drain Problem (F9E1) Error Code 1.Press the power button to cancel the cycle.
2.Unplug the washer or disconnect power to the outlet its using.
3.Turn the power back on and select the cycle you wanted and press start.
Washer Problem (F--E--) Error Code 1.Press power to end the cycle.
2.Open the door to check for excess water in the drum.
3.Press "RINSE DRAIN & SPIN" if there is still water in the drum to remove that excess water.
Suds Routine (SD) Error Code 1.Open the drum at the end of the wash cycle.
2.Remove the clothes from washer, carefully examining them for damage from the excess suds issues.
3.Review your detergent uses to ensure that you're using the recommended type of detergent and the correct amount as stated on the product's instructions.
Maytag 2000 Error LF what does this mean
The LF error code indicates a long fill condition.
What you need to do is check the filter screens where the hoses connect to the unit. Remove the hoses at the back of the unit. The screens are hust inside of the connections. Make sure they are free from any debris.
or
https://www.youtube.com/watch?v=1M-XgRT3obc
or
http://ths.gardenweb.com/discussions/2441868/maytag-bravos-lf-error-code-solved
2answers
What does error code LF on my Maytag 2000 series front load washer mean?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
LF appears after my maytag front loader is washing for about 4 min. We took the screens out, cleaned out and swapped ends of hoses from washer to the water valves. Still not working. Washer only a yea
LF means long fill....if the flow meter does not detect
the correct amount of water entering the machine the
code will appear. Google Maytag front load washer
LF code...there are several links including a video
that should help you solve the problem.
Regards,
Dennis
1helpful
Maytag Neptune front loader makes loud popping noise, shuts off, and trips circuit breaker. Plus, can't get the door unlocked to get the clothes out.
follow this steps and fix it. God bless you
Check Power
Check the outlet by plugging an appliance into the same outlet the washer was plugged into an running the appliance a hair dryer works good for this it will draw some amperage. If it works fine move on.
Control
To check the control remove the top panel and then remove the console to access the wiring to the control. Find the wire feeding the control from the main power cord. If you cannot visually see this refer to the tech sheet or service manual. Connect voltmeter to the 2 wires feeding the control if it is recieving power and it does not respond replace the control
My maytag bravo top loader washer is displaying a code of LF and
it meant "low flow" check water connecting lines. mine has the same problem.
Top Washing Machines Experts
Marvin
Marvin
W.L.
