Hi sir good day the green light indicator flashing which indicates error detected by processor. now here is my solution on how will you fix the problem. if you are going to do it with your make sure you have proper tools and at least a basic knowledge in repairing. now unplugged the unit then open the back cover to gain access the internal part of the tv. now disconnect the connector wire going to inverter board for back light then turn the tv, if the indicator stays green doesn't blink then all the voltage out put from the power supply is normal the 5v stand by,5v switch, 12v and 24v are present, you have bad inverter board or the back light itself. another way is if you disconnect the connector wire going to inverter ballast board then still light indicator flashing and no PS_ON voltage coming from the main board which switch the power supply to turn on i may say you have bad processor board. make sure no bulging capacitors at the power supply replaced it with the same value a panasonic brand FM or FC series much better with low ESR 105c rating. you can find replacement parts at www.digikey.com . hope this will help you feel free to ask further question good luck.
Posted on Aug 20, 2011
SOURCE: tv wont turn on green timer light keeps flashing
I dont know for sure but i got a hdtv someone threw away and was doing the same thing and i popped off the back and right where the power cord goes in there was a blown fuse. Which i bought at radio shack for like thirty cents. That was like nine months ago and still works good.
Posted on Aug 23, 2009
SOURCE: JVC projection TV green timer light comes on, tv turns off
You have listed your set under a category for DLP projection sets, but the problem description sounds more like a CRT based problem. Can you confirm the model number of the unit please?
If it is a CRT based set, the problem is a poor connection at the vertical IC. If you look closely, the single blue line is probably the 3 colors on top of each other. If so, then a resolder of the vertical IC should solve the problem. Once you confirm the model number, I can provide you with additional details and instructions.
Thanks,
Dan
Posted on Sep 22, 2009
SOURCE: Hi, We have a Toshiba rear
It sounds you need a new Projection Lamp; they usually last for 2000 hours or more. The led blinking is the lamp warm-up period and it fails now, if you replace the lamp be careful very static sensitive and blow the dust out with air while the TV is open. Hope this Helps.
Posted on Apr 10, 2010
SOURCE: tv comes on, green light flashes several times,
common problem with that model is the backlight inverter, 1 or more of the six transformers may be bad.also check for bad capacitors.the tedious way to check is unplug each and plug in each one at a time but unplug the power from the tv each time you check one or you will get a nice jolt. the one that doesnt light the lamp is bad.or take each transformer off and check the primary and secondary coils if you find one open coil. the transformers cost between $8 and $20 each.it has a substitute part.
Posted on Jul 05, 2010
Jan 18, 2016 | JVC Televison & Video
Mar 20, 2013 | Mitsubishi LT55164 Unisen Medallion 55...
Jul 21, 2010 | Mitsubishi WS-65809 65" Rear Projection...
Sep 21, 2009 | Mitsubishi WS-65515 65" TV
Aug 09, 2009 | Televison & Video
Jun 13, 2009 | Samsung HLM507W 50" Rear Projection HDTV
Apr 14, 2009 | Samsung HL-S4266W 42" HDTV
Dec 28, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Sep 18, 2008 | Mitsubishi WS-55613 55" Rear Projection...
Jan 12, 2007 | JVC AV-32FA44 32" TV
Jan 20, 2021 | Sony Televison & Video
52 people viewed this question
