Firstly, have you got an Elna metal bobbin? it should be solid on the bottom and have 7 holes on top. It is essential that you always use it this way, wind it with the holes on top and load it into the bobbin holder the same way.
Have a look at the image above, you need to load the bobbin in and click the thread into the tension spring so it doesn't lift back out when you pull the thread upwards. There should be an audible click as it goes in.
If you can't get it right or this image is just too small, feel free to email me and I'll send you the image and talk you through it, I have a TSP machine too.
[email protected].
Also, check my tip on bobbin winding here
http://www.fixya.com/support/r10598580-winding_bobbin_correctly it is important to get a good even tension onto your bobbin as you wind the thread on, you may need to manually add some tension to the thread as it winds off the spool, as I've described in my tip. I sold these machines for Elna and customers would bring them in complaining of problems with their machine. Almost aways, it was the needle in backwards, bobbin upside down, thread/lint buildup in the bobbin race or badly wound bobbin that was the problem.
Hope this helps you Gaylene, but if not, please email, I may be able to send you the relevant manual pages.
I have a service manual for the Star Series Elnas, what TSP do you have? does it have a 2 digit number on the metal plate by the power point so we can work out which one it is? They made several models called TSP, the Lotus, Stella and Star Series all had a TSP model. There was a wonderful website where all the manuals were free to download, gone now, but I saved a few manual pdf files from it. If you like, email me directly, [email protected] and I'll try to help.
do you have any the service manual for the elna supermatic?
