Fisher and Paykel 24 in. DD603H W Built-in Dishwasher Logo
Question about Fisher and Paykel 24 in. DD603H W Built-in Dishwasher
Fisher & Paykel Dishdrawer: DD603: Have had motor & rotor assembly replaced - now F-2 code here is goes again. Determined to have husband fix it!! I hope. Company says it is an issue with the bottom drawer not being used enough. NOPE! I have noticed that the rinse agent dispenser for the bottom drawer seems to run out very soon. Wonder if this is the problem. Maybe gumming up things. How do you address fixing this dispenser?
James Foster
    Novelist:
  • 251 Answers
Hi - F2 error code indicates a failure of the rotor/motor or the sensors, the following notes should give you guys something to check and see which of these has failed..
Error Code - F2
Which LED - Delicate LED
Reasons - The motor has not been sensed rotating
Likely Causes
_ Foreign object has jammed the rotor
_ The rotor has failed
_ The hall sensor has failed
_ The electronic controller has failed
Posted on Aug 25, 2011
1helpful
2answers
I have DW60CDX2 , Turning on but buttons are not responding when I pressed buttons?
from what I'm seeing for the dishwasher, an E1 error means that the door is not properly closed. So, please look at the door of the machine to make sure that nothing is broken or that the dishwasher isn't too full. Thank you.
Fisher and Paykel DD603 can't be drained completely
https://www.manualslib.com/manual/575481/Fisher-And-Paykel-Dishdrawer-Dd603.html?page=22#manual this link takes you to the service manual for your machine, there will be details on manually testing individual components, you should be able to operate the pump and check that it is performing as it should, page 39 describes the process to lift out the rotor, do that and check the rotor impeller, this is the drain pump, if the rotor vanes are broken you will need to replace it,
My Fisher and Paykel dishwasher serial # starts with 88445 ERM - What year was it manufactured? 1995? 2005?
ERM was manufactured June 2005 according to this serial number. The product code (on the model/serial tag) would further refine the dishdrawer details.
2helpful
DS603 fisher paykel motor noise when starting up
The pump and motor for DD603 is the same device. It is a rotor lodged inside a cavity under the drain filter plate. I am assuming the dishdrawer is drained properly and at end of the wash there is no water sitting inside. You need to take the rotor device out from its cavity and check for damage. This video will help.http://www.youtube.com/watch?v=UXzuJvKIIgU
My model number is DD603 The top dishdrawer is draining into the bottom dishdrawer. What is the code to reset the drawers?
the check valve in the bottom drawer may be clogged or defective. the two drain hoses are probly connected to become one.
4helpful
Dishdrawer model DD603 gives fault F2 (Motor). Unit has only been used a few times. What to do? Out of warranty.
Ok this is what you do you need to swap over the motor rotors from top drawer to bottom drawer. check for anything jammming the rotor etc when you take it out. if it works with the other drawers rotor then you need a new motor rotor. cheers
PLEASE GIVE ME FEEDBACK
3answers
Fisher and Paykel DD603 service manual
Check to see if the Child lock is on...Check your email
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Marvin
Marvin
Paul Bade
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
