SOURCE: How do I change the External HD File System From NTFS to Fat 32
back up the data
re format the drive from my computer..
then begin anew..
you know about the file size limitations of 'FAT, yes..
SOURCE: I can't access my files
you might need to update the drivers or reinstall it
if you are having trouble with your drivers
here is a general look at the drivers and how to update them
if your computer came with a motherboard disc the drivers could be on it
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver hope this helps
SOURCE: Lacie moskeyto is undetected in
if your BIOS is set to "allow classic USB support" (or similar terminology), then you are restricted to the drivers available at the date of BIOS version (or your PCs date of manufacture). The reason is, 16gb flash dd not exist n 2006. Most PCs/BIOS before 2006 can only mount 4gb flash memory or less. Most 2007 through early 2009 is limited to 8gb (this is not a restriction for USB HDD enclosures, older PCs can mount hundreds of gigabytes with older BIOS drivers).
1. If your BIOS allows you to change this setting, deselecting it may allow the OS to load a driver (Vista and Win7 both have native 16gb drivers).
2. Updating BIOS, if a newer one is available for your PC is also a solution, as flash media driver updates are almost always included.
3. if neither options are available for your PC, then you can go get a specific driver for this device from LaCie.com
One caveat: LaCie is renowned for slicing flash memory into two partitions. One is usually a "fake" read-only CD partition. This will not work in many updated BIOS, and even some of the newest PCs. USB HDDs can have multiple partitions, but not flash memory. If this is the case with your PC, then again, your only solution will be getting a device-specific driver from LaCie.
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
hope this helps you
hope this helps you
