Question about Niles IntelliPad CI Solo
I need a replacement battery for the McNair Ni-MH 2.4V 2100mAh battery.
Posted by keithbwhitme on
Jose Sosa
    New Friend:
    Problem Solver:
  • 9 Answers
If you take your old battery to a Interstate All Battery they can rebuild your old battery plus they give a one year warranty on it.
Posted on Nov 16, 2011
Chi Chu
  • 8,457 Answers
Tries websites like Amazon.com,Ebay.com to buy it.This a rechargeble battery?Yes buy a battery charger and used it these battery rechargeable 100 times.
Posted on Aug 19, 2011
Is the Dewalt DE9108 battery charger suitable for charging Ni-Mh batteries?
Dewalt DCB105 li-ion XR Battery Charger 10.8V - 20V
For Battery Type: Ni-Cd Ni-MH
Input Voltage: 110V-240V
Smart Charger for Dewalt 10.8V ~ 20V Li-ion Battery
For Brand: DEWALT
Color: Black
Brand New: A brand-new, unused, unopened, undamaged item in its original packaging
http://www.drillbattery.com.au/charger/dewalt-DCB105-charger.html
May 04, 2015 | Dewalt Drills
What kind of batteries do I need? can I use duracel Ni-MH rechargables?
The operating manual specifies to use only Ni-MH AAA batteries and warns to not use Alkaline/Manganese/Ni-Cd batteries. Panasonic web site lists replacement batteries at 19.95 for a pair.
Duracel Ni-MH AAA batteries will be fine.
Dec 10, 2010 | Panasonic (KX-TG1032S) Phone
Recently I purchased Sanyo Eneloop NC-MQN04ES Charger. I need the user manual for this charger. How many hours does it takes to charge 4 aa and aaa Batteries. I charged it for more than 6 hrs. But the led...
This is from the user 's manual i just copy paste it
Specification: Voltage : AC 220V - AC 240V,
Input : 50/60 Hz 6W,
Output : DC 2.4V 220-280mA x2 (AA),
100-140mA x2 (AAA),
LED indicator : ON - charging OFF - Timer off (approx 16hours) Battrey/Charge Time Approximate Hours :
-Eneloop Ni-MH AA (typ 2000mAh) 10(h),
-Eneloop Ni-MH AAA (typ 800mAh) 8(h),
-Ni-MH AA (typ 2700mAh) 13(h),
-Ni-MH AA (typ 2500mAh) 12(h),
-Ni-MH AA (typ 2100mAh) 10(h),
-Ni-MH AA (typ 1700mAh) 8(h),
-Ni-MH AAA (typ 1000mAh) 10(h),
-Ni-MH AAA (typ 900mAh) 9(h),
-Dimension : 118 x 75 x 40 mm
Jul 03, 2010 | Vacuums
When I depress the shutter button to take a photo the green light turns to red and will not take a photo. New battery. Help?
Red light indicates battery is out of charged.
What type of battery are you using?
the recommended battery for your camera is the AA Ni-MH batteries
now if your using this batteries Ni-Mh and charged it still id did the same thing., How long you already used this batteries more than 2 years now? If yes it means the battery or the Ni-MH is already defective it means that the chemical contect of the Ni-MH is already crystallized and for you to solve it you need to reconditioned the battery or may be purchased a new battery. Gudluck!
Nov 04, 2009 | Kodak EasyShare DX4530 Digital Camera
Installed new batteries and the camera will not turn on. The camera has been sitting up for 6 mo. with no use. We used energizer lithium batteries.
Try using recomended batteries:
optional KODAK EASYSHARE Docks with 1 KODAK Ni-MH Rechargeable Digital Camera Battery KAA2HR; 2 Ni-MH batteries AA, 2 lithium batteries AA; 1 KODAK Lithium Digital Camera Battery CRV3; KODAK Ni-MH 2100mAh Battery Pack, KODAK Digital Camera Battery AA (ZR6); KODAK Alkaline Digital Camera Batteries AA; 3 volt DC input AC adapter
You can even contact Kodak direct and they will send you a free CRV3 battery to test with.
(http://graphics.kodak.com/docimaging/US/en/Landing_Page/ServiceSupportContacts/index.htm)
Oct 26, 2009 | Kodak EasyShare C653 Digital Camera
Cannot power on to take photos
I found that one has to use their batteries of at least 2100mAh and NI-MH. I recharged my batteries removed the new ordinary alkaline batteries I had put in and BINGO IT WORKED. Just to prove the point I put in another set of Alkaline batteries No good. It must be that NI-MH Batteries rated at 2100mAH have more power (or one can draw more currentat start up) a battery guru could maybe veryify my conclusions. Anyhow try NI-MH batteries and see how you go. Best of luck fredlich
Aug 15, 2008 | Sony Cyber-Shot DSC-P93 Digital Camera
Can't use chargeable batteries
If your camera doesn't work with NiMH, then it's most likely that you have either one or more bad atteries, or your camera is defective. p. 6 from the user guide: "..Ni-MH batteries left unused in storage for long periods can become ?deactivated?. Also,repeatedly charging Ni-MH batteries that are only partially discharged can cause them to suffer from the ?memory effect?. Ni-MH batteries that are ?deactivated? or affected by ?memory? suffer from the problem of only providing power for a short time after being charged. To prevent this problem, discharge and recharge them several times using the camera?s ?Discharging rechargeable batteries? function. By repeating this cycle several times, the temporary reduction in performance caused by ?memory? or ?deactivation? can be remedied and the batteries can be restored to their original performance levels. ..." Sorry i cant help you more..
Dec 23, 2005 | Fuji FinePix A310 Digital Camera
Fully charged battery last
Approximate number of recording images and playback times based on Minolta' s standard test condition* are as follows: *test condition: CIPA-compliant. (LCD monitor on, 1600x1200 size images, Normal image quality, Flash used with 50% of the frames) Recording Alkaline batteries : Approx. 80 frames Ni-MH batteries (2100mAh): Approx. 410 frames CR-V3 : Approx. 720 frames Playback Alkaline batteries : Approx. 275 min. Ni-MH batteries (2100mAh): Approx. 340 min. CR-V3 : Approx. 518 min.
Sep 19, 2005 | Konica Minolta DiMAGE E323 Digital Camera
What is BP-400?
BP-400 is a exclusive external power battery pack for DiMAGE A1 and A2. It can be attached to the body and has portability and movability. It is very convenient for the customers who want to use AA size battery or take a long time picture. One or two exclusive lithium-ion battery NP-400 can be attached. 6 AA batteries; Ni-MH and Alkaline battery can be used. (Nickel dry battery and lithium battery cannot be used. Recording: Approx. 560 frames,continuous playback: Approx. 480 min.(2 pcs. NP-400 batteries) Recording: Approx. 290 frames,continuous playback: Approx. 270 min.(6pcs. 2100mAh Ni-MH batteries) Recording: Approx. 80 frames, continuous playback: Approx. 80 min. (6pcs. Alkaline-manganese batteries) Standard Accessory: Holding Strap HS-2 Optional Accessories: Dedicated lithium-ion battery (NP-400), battery charger (BC-400) INPUT: AC100-240V/50-60Hz, OUTPUT: DC8.4V 700mA
Sep 15, 2005 | Konica Minolta DiMAGE A2 Digital Camera
Niles IntelliPad CI Solo Logo
945 people viewed this question
Top Niles Televison & Video Experts
Marvin
Marvin
Are you a Niles Televison and Video Expert? Answer questions, earn points and help others
