Question about Vtech V.reader Animated E-book System
It keeps saying touchscreen calibration utility touch crosshair to calibrate. we'v done everything that we could to fix it. it will not go back to the page with activities.
Posted by vanessaan972 on
  • Maryvonne Pigeot Oct 01, 2013
    while downloading it says"the smartscreen saver online is temporarily unavailable" what does that mean ???
Anonymous
    New Friend:
I need help I buy my son V.reader for Christmas it say Touchscreen Calibration Utility Touch Crosshairs to calibrate. I need help? how do I fix it?
Posted on Feb 20, 2012
skoumartin
    New Friend:
  • 4 Answers
This problem occurs when the Storio device needs to be updated with the Storio Recovery Card.
Please follow these steps:
- Insert a SD-card (with at least 64 MB) in your computer
- Go to the VTECH website www.vtech.com
- Select your country/region + Electronic Learning Toys
- Go to 'Service & Information'
- Go to 'Downloads'
- Download the 'Restore Storio Map-maker' to your computer (not to the SD-card)
- When the .exe file is saved on your computer, open it, and follow the step-by-step instructions for recovering your Storio
This should solve your problem. If not, you can contact the VTECH customer service:
- Go to 'Contact'
Posted on Feb 27, 2013
Mrs. Herd
    New Friend:
  • 3 Answers
You have to go here, download, put the SD card into the computer, let it do it's thing - then, put the SD card into the VReader, let IT do IT'S thing, LOL, then take the SD card out of the VReader and it's done! Mine was stuck on the calibration screen as well, but this fixes it - you have to do this to set it all up correctly. It's part of the download process. It will give you step by step instructions :)http://www.vtechkids.com/download/
Posted on Jan 23, 2013
Can not calibrate the screen
Here is the procedure to calibrate the screen if you can not reach the calibration screen through the GPS menus.
Nuvi 2xx/2xxW Series: Turn the Nuvi off. Place your finger on the upper left-hand corner of the screen and then slide the on/off power switch to the left and hold until you see the calibration screen. Note: Some 2xxW models require the procedure below for the 7xx.
Nuvi 7xx Series: Turn the Nuvi off. Touch the screen anywhere and keep your finger there while moving the on/off switch to left (don't wait for Garmin logo to come up) and then quickly moving the switch the right (lock position). After a short while, you will reach the calibration screen. Go through the entire procedure of pressing each dot as it appears on the screen until it says "Done".
Now if you go through and press the dots and it keeps looping without saying "calibration complete" then the touchscreen has drifted out of specification and must be replaced.
Please see this link for more information about touchscreens and how to get it replaced.
http://www.sharc.net/gps_LCD_repair.htm
Radio stations
There is a radio option to recalibrate your touch screen. Please press the following three hard keys simultaneously RADIO/MEDIA, SEEK UP, NAV (AUDIO on REN). Once you begin to recalibrate the touch screen you must finish. Audio confirmation prompts are provided for each of the three points of calibration, one beep for the first, two for the second and three for the third. The calibration needs to be precise as possible and a PDA stylus would be recommended. The MyGIG radio requires the user to repress each calibration point to confirm the calibration process. A green crosshair indicates proper calibration.You must not start with the "+" but with the "+1", then goto "+2" and last to "+". Repeat this until all crosses are green and exit with pushing the menue or any other key. Done
Ello My problem is when i boot after a factory reset i have touchscreen to calibrate and when i do it it gives me try once again it's stuck there
I am not sure you are talking about a tablet PC or the new craze of tablets.
For the tablet PC you should have a screen calibration utility. You can calibrate the display for the Wacom (or other) pen, or for the touch input.
When you calibrate the pen, any touching of the screen with anything other that the Wacom pen will be ignored.
Similarly, when you calibrate the touch, any input with the Wacom pen will be ignored and you will be asked to use the proper instrument.
To get back to your case , it is possible that you are not putting the finger at the right place or not pressing hard enough. That is just a guess and I may be off the mark for the new tablets, but not for the Tablets PC:
8helpful
2answers
Touch crosshair to calibrate is on my screen how do I get back to main menu screen?
my android saying touch crosshair to calibrate try once more how i can get back my main menu please
17helpful
4answers
Vtech storio in touchscreen calibration mode
Hello I buy my son the V.reader for christmas the next day it say Touchscreen Calibration Utiliy, Touch crosshair to calibrate I need help
1helpful
Does not work on the edges, can not access start by touching. when the screen is touched the arrow appears about half an inch away
Sounds like the calibration for the touchscreen needs to be reset. If you check in the control panel, there should be a ELO shortcut that allows you to calibrate/test the touchscreen. Try running through the calibration and see if the touchscreen behavior improves. If the calibration doesn't fix it, then you may have an issue with the touchscreen itself.
16helpful
When the main screen comes on and says touch your name with the pen it does not resond what do i do?
It sounds like the TouchScreen needs to be calibrated.
1. Hold down the Hint button while turning the Leapster on.
2. When the Leapster menu screen appears, press the A button.
3. Touch each of the crosshairs that appear with the stylus.
4. Restart the Leapster.
Hope this helps!
Feb 27, 2011 • Leapster 2
Panasonic Toughbook CF-30 Touchscreen Calibration
Your touchscreen is defective. Please contact Panasonic official service center http://heartlandsi.com to arrange a repair. It's covered under warranty.
4helpful
12answers
UNABLE TO CALIBRATE TOUCH SCREEN
The only possible fix is to try to clean the edges of the screen in case any particles are trapped between the screen and the case, this can confuse the touch screen.
Do this with a soft toothbrush, it will not damage the screen.
If that doesnt work then in all likelihood the screen is broken, it can be replaced but this is not trivial. There are guides on the internet on how do do this.
Vtech V.reader Animated E-book System Logo
Top Vtech Toys Experts
tina gallow
GI Consulting
Tom Chichester
Are you a Vtech Toy Expert? Answer questions, earn points and help others
