Dyson DC14 Animal Bagless Upright Cyclonic Vacuum Logo
Posted on Aug 19, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When my Dyson is upright it has suction, but when I pull the handle back to vacuum, it looses suction.
Think Crucial
Level 3:
Master:
  • Dyson Master 894 Answers
  • Posted on Jul 23, 2017
Think Crucial
Dyson Master
Level 3:
Master:
Answers
894
Questions
0
Helped
711229
Points
8395
Hello, this is Ava with Think Crucial.
To fix any you vacuum problem, a proper maintenance will do the trick. Most of the time cleaning the filters, checking for blockages and clearing the passageways, and cleaning the brush roll assembly will resolve this. And if after doing maintenance it is still the same, that replacing the parts will most of the time make your vacuum work like brand new.
You can purchase a wide variety of high quality Dyson replacement parts for your Dyson vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=dyson
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
1 Related Answer
Anonymous
  • 7 Answers
  • Posted on Nov 07, 2007
SOURCE: No suction in upright position
Check the adapters at the bottom. They're supposed to move cleanly when you lower the handle. It's pretty obvious if there's an air gap when you lower the handle, and you should hear the suction in the air gap.
And...call Dyson...their support is great!
My vacuum is stuck in upright position
It's frustrating, but it's a common mix of vague documentation and un-obvious operation for a lot of Dyson uprights. Per the manual (
https://www.dyson.co.uk/medialibrary/Files/Dyson/Support/downloads/UK/floorcare/Manuals/dc27_uk_manual_alf_120710%20pdf.pdf ), look at page 4, you put your foot on the base of the unit and pull back with conviction on the handle. It should move. If it's feeling really iffy, make sure that the hose assembly is fully clicked into the base.
Be aware that the brush bar won't spin until the unit is reclined. This is a common feature in Dysons, since this is the position where it re-routes the suction into the handle for use of accessory heads.
Good Luck!
2helpful
Handle vacuum no suction
I have made a video of the two most likely causes for lack of suction in the handle of your dyson DC07. Watch the video and see if it helps. The other thing to check is your washable filter, this can cause a big resuction in suction if dirty. If this is helpful take a moment to leave a testimonial or a thumbs up please.
Hope your back to full suction soon. :)
The wandcap for my dyson vacuum doesn't stop the air from flowing though the wand. If your first responce is what model dyson ---then don't bother responding.
The cap on the DC07 should allow air to flow through when the handle is in the upright position. When you pull the handle back, there shouldn't be suction in the handle.
Loss of suction when upright
Check the Rubber Air seals and bottom Hose for splits.
7helpful
2answers
No suction on wand of Dyson DC14 Animal
Hi its Darran at Dyson.
It sounds as though the wand handle is blocked. To check this, remove the wand/hose from the machine as if you were going to use it to vacuum the stairs. Switch the machine on and test the suction at the top of the wand handle with your hand. If the suction from the wand is poor, remove the wand from the hose and test the suction again from the top of the hose. If the suction here is good, then you know the wand handle is blocked. If the suction is poor at the hose, you can remove the hose from the machine and clear any blockages here.
For the full blockage procedure please visit the support section on our website at www.dyson.com.
Kind regards
Darran
Dyson customer Service
No suction when using the hose.
The beater bar is supposed to stop when the vac is upright. Sounds like you have a clog. There are several access points to check, fairly easy to clear obstructions.
1helpful
The vacuum works through the wand only. how do you get the vacuum to revert to the floor usage
You have to put your foot on the front of the machine and pull the handle back. If it is a case of poor suction that you are experiencing, call the Dyson helpline, they will troubleshoot a possible blockage with you.
2helpful
3answers
Suction loss when handle is tipped back to clean carpet
can any one help,
Our Dyson Animal vacuum has plenty of suction when it is upright and the attachments are being used off the hose, but when the handle is tipped back to begin cleaning carpets the beater head is getting no suction. As the handle is being tipped back you can hear what sounds like a flapper valve in the body of the vacuum opening and then all the suction just goes away.
Top Dyson Vacuums Experts
AskDyson
AskDyson
Sean Wright
Sean Wright
xxxxxx xxx
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
