Question about Whirlpool (ED2FHGXSQ) Side by Side Refrigerator
I have an ED2FHG side by side Whirlpool Fridge. The ice container was full and the lever was in the down position when I opened the freezer. Then I noticed that my freezer was dripping water from the ice maker onto a coil in the bottom of the freezer. The coil was red hot when the water was hitting it. I turned off the ice maker and the drip stopped and the coil stopped glowing red. Do you know what the problem could be? Are there any steps that I can take to diagnose the problem? Thanks, Brett
Posted by bhullah on
Leo Ponder
    President:
  • 3,773 Answers
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
If you still have trouble GO HERE:
http://www.applianceaid.com/procedures.html
I'm
including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Posted on Aug 19, 2011
1helpful
Model #WSF26C2EXY02. Why is ice maker not making ice?
When the ice-tray is full it pushes 'UP' a lever that shuts the water supply off. When you move the lever down all goes back to normal.
Kenmore fridge model 596 - 79213014 2 yrs old accumulates ice at the bottom freezer. The fridge has built it ice maker but we did not opt for that option. Can anyone pls advise how tofix the problem?
IS THERE A CONTAINER FOR THE ICE TO COLLECT IN UNDER THE ICEMAKER??? IF NOT YOU WILL NEED TO GET OR ORDER ONE..
NEXT THERE IS A WIRE LEVER ON THE RIGHT SIDE OF THE ICE MAKER. WHEN THE ICE PUSHED THAT LEVER UP IT WILL QUIT MAKING ICE. WITH YOUR HAND GENTLY LIFT THE LEVER UP UNTIL IT STAYS LOCKED IN THE UP POSITION... ONCE IT IS IN THE UP POSITION ... IT WILL NOT PRODUCE ANY ICE.
1helpful
Whirlpool fridge freezer
The fridge side is cooled by the freezer side. Try unplugging power, open freezer door and let thaw out/defrost.
Ice cube dispenser
make sure the ice maker lever is in the down position, when removing the tray the arm was probably moved to the top(off) position as if the tray was actually full which would shut off the ice making process
1helpful
Intermittent flapping noise whirlpool fridge freezer
Hi: Go easy on my rating as this is just something to try. You say it dosn't have a dispenser. Does it have an Ice maker? If so is it hooked up? If not try raising the lever on the ice maker up to the off position. The water valve may ve trying to open and without water pressure it will make a noise. It would also be related to the switches on the door. I hope this helps, Jeff
2helpful
2answers
Icemaker not producing ice
Most automatic ice makers have a lever (looks like a piece of wire) that is prevented from being in the down position when the bin is full. This stops the ice maker from producing ice when not needed. The lever can also be lifted manually to a locked up position which turns the ice maker off as well. If the lever is in the up position, simply press down on it, it should release and return to the down position. Once down, the ice maker will begin producing ice again (the unit will have to complete its cycle before you see any ice, normally a couple hours or less). Hope this helps.
Please take the time to give this solution a fix ya rating.
clarkco
Ice maker does not work.
Make sure the wire lever is pushed down calling for ice.Otherwise the unit thinks its full.
3answers
Freezer not making ice in Fridgidaire model PLH269ZDB2
There is a lever in the ice bin that detects when it is full. if that lever is locked in the"up" position, the maker stops making ice. Many times a previous owner or a shipper will turn off the icemaker this way. especially if the water to the home or freezer is turned off, so it won't keep trying to make ice.
2answers
Ice maker on Admiral HMG 62165 side by side
check the lever in the ice bin. if it is stuck in the up position it thinks the ice bin is full and will not make ice. Just wiggle it to the down position.
Whirlpool (ED2FHGXSQ) Side by Side Refrigerator Logo
Top Whirlpool Refrigerators Experts
Dan Webster
Dan Webster
Michael Thomas
Michael Thomas
jdthefixer
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
