Question about Kitchen Ranges
Our sleep number bed remote control shows "Er" and nothing we do seems to help. What can we do?
Posted by randy_sus129 on
  • Wilson Mowbray
    Wilson Mowbray Oct 10, 2013
    If this procedure fails, try un-plugging the pump, start the countdown by pressing the up ans down arrows(one side only) and plug in the pump during the countdown. This worked for me.
Sonja Stanier
    New Friend:
  • 22 Answers
A code of "Er" indicates a communication failure between the Firmness Control™ System's base unit and the remote. To fix this issue please follow these steps: 1. Make sure that the Firmness Control™ System is properly connected to your outlet and the power cord is securely connected to the base of the Firmness Control™ System. If the Firmness Control™ System is plugged into a surge protector, make sure it is on. If the outlet is wall-switch controlled, check that it is also on.
2. After verifying your Firmness Control™ System has power, you will need to resynchronize the remote to the base unit. The resynchronization steps must be completed within 60 seconds:
  • Unplug the Firmness Control™ System and plug it back in.
  • Press any button to "wake up" the remote.
  • Your Firmness Control™ System should now be free of the ER code; however if this does not solve your issue, please follow these steps:
    • Simultaneously press the softer (down) and firmer (up) buttons on the remote. The remote display will count down from 10 to 1, then "--" will appear followed by "C1".
    • After "C1" is displayed, release both buttons.
    • Simultaneously press the softer and firmer buttons again and "1C" will appear.
    • Release the buttons and the proper Sleep Number setting will be displayed.
Should the problem persist after completing the above resynchronization procedure, please email or call Customer Service at 1-888-484-9263.
Please leave feedback if you find the answer helpful. Regards KatBell
Posted on Aug 19, 2011
  • Cheryl Brunton-Dubbs
    Cheryl Brunton-Dubbs Jan 16, 2014
    Thank you so much. Perhaps now that I can adjust it again I can get a good night's sleep once more!
  • Anonymous Nov 18, 2016
    Thank you very much it did the job and I can now reset the pressure
My mom said when she got into the bed she hit something on the remote and name we cant get the pick back. something about dta status keep showing please help
sorry nothing we can do from here about hitting buttons as can not begin to see what it shows . FIDDLE with it
Dec 21, 2016 | Televison & Video
Is there a fuse on the orthomatic beds
Yes. There are 7 of them; at the bottom side of the bed.
Aug 08, 2016 | Televison & Video
I have the adjustable bed, but have lost the remote control. Two #'s that I see are 17500249 & 062805.
ADJUSTABLE BED ACCESSORIES AND SERVICE
adjustablebedmart.com/accessoriesservices.html
REPLACEMENT HAND CONTROLS We have both hard wired and wireless remotehand controls. Does your hand control look like one of the two on the left?
Sleep Number Bed Replacement Parts ' Sleep Number
www.sleepnumber.com/sn/en/.../bed-replacement-parts
Select ComfortREPLACEMENT PARTS. Remote control. Most issues with your remote can be easily resolved by following certain troubleshooting steps. If your remote is ...
Jan 25, 2016 | Televison & Video
Craftmatic
Why not refer this problem to Craftmatic directly?
Nov 28, 2012 | Televison & Video
What is the best way to determine what size bed my dog needs?
First you need to determine how your dog sleeps - this will be very important in your decision making process. If your dog sleeps curled up in a ball, then a nest bed would be your best choice. You should measure your dog while they are sleeping curled up and then add 7 inches to properly determine the length you will need. If your dog prefers to sleep stretched out, then you will need either a standard bed. Measure your dog and add 12 inches to determine what length bed you will need.
Jul 18, 2012 | Dogs
My Adjusta-magic control for my Englander bed will not work. HELP PLEASE! The foot of the bed will not go down.
1) You must open the foot of the bed , and see for the switch, and test it with a VOM, see for open , tight any wires loose cables, or broken and repair. God bless you
Jun 13, 2012 | One For All URC-3300 Remote Control
I need instructions on operating a remote to Sunbeam,Cal-King, electric mattress pad.
Which model Sunbeam mattress pad do you have? Sunbeam has some of their manuals here: http://www.sunbeam.com/manuals.aspx . The electric bedding share a manual. The direct link is http://www.sunbeam.com/BeddingManuals/SunbeamBedding/Universal.pdf .Make sure that you are using the master control for your side of the bed (that's the one closest to the plug for the wall outlet).
You may need to turn on the second control and set it to 0 at night. If you still are having a problem with the heat being uneven, you might need a replacement mattress pad. I know we've replaced several electric blankets or mattress pads due to problems with the control/uneven heat.
I hope this helps.
Jan 25, 2012 | Heating & Cooling
My KLH 5100 System worked fine for nearly a year. Very suddenly the remote control seems to have no effect on the unit. It doesn't switch it on, or off, or change the volume...nothing. I changed the...
Read this procedure to possibly fix the remote:
http://remotes.com/remotes/servlet/rs?a=Display&contents=help_deadremote&uuid=A12963989782821
They also sell replacement remotes.
Zoom in on the picture of the original remote provided on the site (or look at your own) and get the actual remote model number.
or check eBay: search for "(model of the device or the remote) remote", check the 'include description' box. Usually cheaper than the vendors.
Sep 08, 2011 | KLH R5100 Receiver
Do i need to buy a new remote control
i ended buying a new remote control it did have a few more than what i had to get me back to where i needed to be it just did'nt have eveyone of them but than again i bought it at the dollar store am going to check out one of the bigger stores
Oct 25, 2009 | Samsung TV Remote Control
Universal remote control ER 480
The ER-480 doesn't have a zero button. It only has numbers 1 through 12. How do you enter codes with zeros? I am trying to tune in a Bush DVD player, but I am having difficulty doing so. Can anyone help? Many Thanks in advance.
Jul 18, 2008 | Televison & Video
Kitchen Ranges Logo
24,177 people viewed this question
Top Kitchen Ranges Experts
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
