Question about Ariston Technologies AW129NA 16 Lbs Front Load Washer
I inherit the Ariston AW120 washing machine with the COndo I just purchased. I ran a cycle on the machine but the door will not open. How can I open the door? why does it not open after the cycle is done?
Posted by eric385 on
5 Related Answers
Anonymous
SOURCE: Ariston AWD 120 Door Handle is Loose
unplug it.
open the top lid.
reach down inside and feel a plastic sensor/release behind where the latch is.
towards the left center of that sensor, feel for a metallic manual release (you'll just feel the nub of it).
Push this in and to the side to manually release the door lock.
Call Ariston and complain about this common problem.
Posted on Nov 09, 2007
Anonymous
SOURCE: ariston 6kg washing machine
Do you have the "easy iron" feature on? If so, the clothes will stay in water until you manually rinse it.
Posted on Jun 13, 2008
barkencoa
Barry Coates
  • 3463 Answers
SOURCE: Ariston Margarita 2000 NOISY spin cycle....
Remove drum drive belt, and spin drum by hand, if there is any resistance,. or it feels rough or noisy, the the main bearigs have probably failed.
If it is o/k then check motor for worn or noisy bearings,
Please rate my solution.
Thanks.
Posted on Jul 24, 2009
Anonymous
SOURCE: Ariston A1635 Margherita Control knob spinning
According to the instruction book - it appears the machine has been stopped mid cycle then re-started.
Switch machine off, turn control knob to a solid circle symbol (they are after every set cycle). Switch machine back on and lights will flash and program is reset. You can then select wash cycle as normal.
Posted on Jan 23, 2010
SOURCE: instruction manual for aw120
Here you can get manual for this model http://www.managemylife.com/mmh/lis_pdf/OWNM/L0520683.pdf
Posted on Nov 18, 2011
How to unlock the door
Lamp M flashes slowly when the appliance is switched on and
a waiting instructions and at the end of a cycle, indicating that the door can be opened. It flashes quickly when the door should not be opened. A steady light means the appliance has accepted the selected programme.
24967037-ineink0kisfnom0atbkujjcx-3-1.jpg If you correctly use the appliance then defective can be interlock, wiring or board.
If the door is constantly locked then you can access to interlock by removing the top cover of washing machine.
Dado
Aug 17, 2014 | Ariston Technologies Ariston AWD12 Front...
Constant clicking of door lock
Suggestion: Try a little WD40 spray on the door, not on the machine. Close and open 2 or 3 times while plug is off the wall mains.
Click if helped.
Apr 14, 2013 | Ariston Technologies Ariston AWD12 Front...
Cannot open Wash door
Here is a tip that I wrote about how to get your washing machine door opened...
Washing Machine Door Jammed
heatman101
Jan 24, 2011 | Ariston Technologies Ariston AWD12 Front...
Hi, We just moved into
On the bottom of the rubber seal, there is a drain hole. Check to see if it is clogged and clear it out if it has an obstruction.
Jan 01, 2011 | Washing Machines
Broken door handle on washing machine
You can purchase any of the parts individually for the door handle.
If you go on line and enter Ariston door handle in search box, you shuold be able to locate the part/s you require.
Good luck.
Jan 06, 2010 | Ariston Technologies AW125NA 13 lbs. Load...
Instruction manual for aw120
i have the same model and can make and copy and send to you if you like ?
are you having any problems with your machine ?
i just started to have some issues with mine today actually....just wondering if yours is not working right either ?
c
Jun 26, 2008 | Ariston Technologies AWD 121
unplug it.
open the top lid.
Nov 04, 2007 | Ariston Technologies AWD120 13 lb. Washer...
Smelly machine
problem is probably tjhat liquid detergent has been used - gives a smell loke drains. put on a boil wash without detergent and use powder detergent
Apr 05, 2007 | Ariston Technologies LBE12X Ariston
Door wont open
Try first to unplug the power cable. In case it will not help,you have to raise the top of the washer to get to the switch (near the door)and try to open it manually. If the problem will return,you should replace the switch. Good luck!
Oct 01, 2006 | Ariston Technologies AWD120WH Ariston
Ariston Technologies AW129NA 16 Lbs Front Load Washer Logo
300 people viewed this question
Top Ariston Technologies Washing Machines Experts
Marvin
Marvin
Harrie
ray gallant
Are you an Ariston Technologies Washing Machine Expert? Answer questions, earn points and help others
