SOURCE: HP Color LaserJet CM1312nfi MFP printer leaves a 2
turn on/off, unplug, plug in, should reset configs.
take all the paper out, put half as much back in.
check the rollers to make sure no paper or particles are preventing printing
go to applications folder for your computer, dbl click printer icon for make of printer. check settings. print 'test document and clean cartridge heads', this should ensure proper printing formats.
lastly, go to web site of printer model and check site for trouble shooting if this does not work above. HP has an awesome website for this type os trouble shooting
hope this helps and good luck
SOURCE: HeLp! My HP CM2320nf MFP is printing blurry!
This is nowhere near the solution. I have seen this twice. It occurs when the Magenta and possibly other laser mirror assemblies are misaligned. Disassembling this monster is a monster job. It also means that you must have the Service Manual and great patience and skill, as the manual is not very detailed or thorough.
SOURCE: We recently purchased and installed an HP Color
Hello !
I would try replacing the printing driver
Try downloading a Postscript Universal print driver, you can get them from www.hp.com
SOURCE: When printing text in color
Clean the Fuser unit and Remove the Wasted Toner from the Drum, that'll definitely fix your problem. To do these, you have to disassemble the Fuser and also the Drum. If you need further help, let me know with more details so that I can give you the instructions on how to do and how to fix it with the easiest possible hints and instructions.
Awaiting..
Good luck.
SOURCE: I have an HP Color LaserJet CM1312nfi MFP printer.
I have the same printer and you have to set the default paper size in the printer itself to legal.
