Our Element TV, EN36071, purchased from Walmart about 16-18 months ago continues to display closed captions. We have tried going into the setup and a closed caption option doesn't show up on the screen to change it. We then tried using the remote control and press the CC button, and it doesn't do anything either. We looked at the Users Manual and it references going into the Setup Screen and when we do exactly as they say, the Closed Caption is not an option anywhere for us to select to change it. Do you have any suggestions to remove the closed captions from the TV? This has been occurring for months now and is terrible.
Turn on the TV. Press the Menu on your remote (or on your TV screen) to display the Main Menu. Use left or right arrow (button) to select the TV "SETUP".. Use the up or down arrow (button) to select the CC (closed captions) SETUP option. Select the analog & digital mode and use the left or right arrow (button) to switch/toggle it to OFF (by pressing the OK button).
This process may vary slightly depending on the TV (make & model).
When you turn it off are you going into the setup menu to do this?? if so after it comes back on and you go back to the menu and you see it..as "on" You will need to save your settings before you exit out of the menu
Hello After switch ON the TV, and after picture has displayed on the screen with 'closed Caption" window, just press button "CC" on your remote control. For each press, the close caption window will vanish and disappear. OK.
Using this button will set the Closed Caption mode when viewing a DTV or TV channel.
Enable Caption Using the TV Menu
Open the Menu screen, select the third icon, in the middle, this is the Setup Menu.
In the Setup Menu, choose the Caption option.
Caption: There are three items in it - Analog Closed Caption, Digital Closed Caption and Digital Caption Style
Analog Closed Caption: CC1, CC2, CC3, CC4, TEXT1,TEXT2, TEXT3, TEXT4.
Digital Closed Caption: Service1, Service2, Service3, Service4, Service5, Service6.
Digital Caption Style: There are two Caption Styles. One is the
automatic function set as the broadcaster, while the other is the custom
style where you can adjust the font size, color, opacity, background
color etc., accordingly.
Hello
To enable close cationing on your TV follow this:-
[1] Press "Menu" button on the remote control to appear "Setup" menu on the screen.
[2] Use "Up and Down" arrows on the remote contol to select "Captions/Text" on your screen.
[3] Press "Right or Left " arrows to select any one of the following options. Caption-1, Caption-2, Caption-3, Caption-4 Text-1, Text-2, Text-3, Text-4.
[4] Press enter to return TV viewing.
To turn the caption feature to "On" or "Off'
[1] Press menu key on the remote control to display "Setup" menu.
[2] Using "UP/DOWN" buttons to select captions on your screen.
[3] Press "Right or Left" arrow to switch the captions feature 'ON" or "OFF" or "EZ Mute"
[4] Press enter to continue.
Ok.
The easiest solution is to purchase a universal remote control. I just purchased one from Walmart for $4.94. The setup is easy as there is an "auto-search" that identifies the code for your TV. Once it's setup, life gets a lot better.
Joe from what you describe it sounds as if the closed captioning display is turning on either through the tv or cable box if your's has that capability. Go to the menu on the tv and go to the setup option, from there you should be able to locate the closed captioning option and turn it off or disable it. The same may need to be done with your cable box if it is closed captioning compatible. I hope this is of some assistance to you. If I can help in anyway please let me know.
look on top and behind of the monitor you will find buttons for your TV then follow this steps:
The Setup menu lets you configure the TV to fit its surroundings and your preferences. To access the Setup menu, press MENU, and then select Setup from the Main Menu.closed caption options are:
CC Setting Lets you choose the way closed captioning information appears on the screen.
Off No captioning information displayed.
On Always Captioning information shown always, when available.
On When Muted Displays captioning information, when available, whenever the TV?s sound is muted by pressing the MUTE button. The captioning information is not displayed when the sound is not muted. Make sure all of the options for closed caption are off press exit and you are good to go.
