There are bad solder connections on the vertical output ic. if you can solder well, get an iron with a fine tip and look for an ic mounted to a metal heat sink. it will be about an inch or so long with 7-9 pins all in a row,on the under side of the board you can usually see the the rings around the pins if you look close or use a magnifying glass. i have fixed dozens of these using only a hot soldering iron and rosin core solder.
