Question about ViewSonic VP211b 21.3" LCD Monitor
V LCD Monitor D19W12 how do I adjust color - it is all PINK?
Posted by merrymiss on
ikkenom
    Brigadier General:
  • 10,406 Answers
Make sure that the "data" cable between the computer and the monitor is tightly-connected at both ends.
Try a different "data" cable.
Try connecting the monitor to a different computer (laptop or desktop).
Note that 'WHITE' is generated by mixing all 3 "primary" colours.
If the video-card on your computer is not generating all 3 colours, then 'PINK' could be the result from mixing the remaining 2 "primary" colours.
Posted on Aug 19, 2011
Why does my new ASUS VE278H have a overall pink screen color that won't go away with color adjustments?
You have a faulty/damaged screen but you might also check your video colour settings in windows/linux whatever OS you use
May 06, 2014 | ASUS VE278H 27" LED LCD Monitor - 16:9 - 2...
Color is pink, can't seem to adjust.
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 12, 2014 | Toshiba 26HL84 26 in. HD-Ready LCD...
When i start my PC on the screen where there is pink background color their I see all pink color replaced with small - small red pixels .... I have adjust and done all possible method on Menu(Setting)...
Pink and pink streaks are a sign that the CCFL lamp is about to fail. The CCFL lamp provides the backlight to the monitor.
To confirm that the monitor is faulty and not the video card, connect a different monitor to your computer.
To replace the CCFL lamp requires removing the front screen bezel, removing the LCD screen from the frame and the reflector which is located on the bottom edge of the LCD screen. The CCFL lamp is located inside the reflector and the electrical wires on the ends of the CCFL lamp are connected to the inverter board.
Replacement parts are available from these WEB sites.
LCD screens and Inverters www.lcdparts.net http://www.yallstore.com http://www.shope2.com/ http://www.invertercentral.com/qrySearch.asp?Adword=1500&search=1500&Campaign=Google-Models-NA&gclid=CO3lg7HJlKMCFQcbewodZB2qoQ http://www.nylaptopparts.com/ http://www.ccflwarehouse.com/
May 14, 2011 | Samsung SyncMaster 740N 17" LCD Monitor
I made adjustments to my monitor to change the brightness but now all my monitor has a pink tinge to it and all my photos in photoshop are pink. How can I set the monitor back to the factory settings
sound like a loose connection, check all your cables and make sure they are securely attached to your computer and also the back of your monitor, if problem persist try going to the degauss menu and degauss the monitor, check to see if your color settings are properly configured, also check the color temperature. If none of these suggestions worked your monitor may have a more server problem, hope this helps, best of luck
Feb 06, 2011 | LG 22" FLATRON LCD Monitor
The color / hue on my sony monitor seems to be pink how do I adjust it to its normal color ?
Click on the link below and download the manual to know how to change settings of your monitor
Monitor Settings Manual
Regards,
Shawn
Feb 03, 2011 | Sony SDM-HS95 19" LCD Monitor
The color is "off" on
ladywoman197, 2 things for you to do. 1. disconnect-reconnect vga cable a few times from the DB15 vga port on the pc. If problem (pink hue) persists then try here: http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-blackout-solution/ Your unit may need some new capacitors installed on the power supply printed circuit board. Read fixya profiles of "budmrtn" "12fixlouie" and also visit youtube for video clips of lcd monitor repair. Do the vga cable thing first!!! Could also be vga graphics card inside pc not making good contact with monitor cable. 12fixlouie
Nov 08, 2010 | HP W2007 LCD Monitor
My LCD monitor turned Pink
The reason its pink is that the backlight bulb is on its last legs. They turn pink or reddish before they go out completely. Eventually the backlight will need to be replaced.
Please rate this fixya
thanks
May 04, 2009 | Computers & Internet
SVA 17" flat monitor screen color is pink.
It's not a "windows" problem. At the bottom of your monitor there should be a 'menu' button. Push the button and use the up and down, right and left arrows on your keyboard to scroll to color. Get the "red" color and adjust it down. You can also scroll through to 'contrast' and adjust that. You don't need to pay a bunch of bucks to have this fixed.
Apr 10, 2009 | SVA-USA VR 17S 17" Flat Panel LCD Monitor
ViewSonic VP211b 21.3" LCD Monitor Logo
136 people viewed this question
Top ViewSonic Computers & Internet Experts
Ekse
Dimitar Todorov
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
