Garden Logo
Posted on Dec 12, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Have a homolite string trimer model ut41112 that i can not get the spool housing off of the drive shaft I have pushed the puton on side of the housing and pulled on the housing at the same time but itn will not come off I can see the slide and have tried to line it up so that the housing will come off to no avail.
Clyde Ottaway
Level 3:
Loyalty:
Visited the website for 30 consecutive days.
  • Homelite Master 1,669 Answers
  • Posted on Dec 15, 2017
Clyde Ottaway
Homelite Master
Level 3:
Loyalty:
Answers
1669
Questions
41
Helped
490154
Points
2465
Check and see if there is a hole on the end of the shaft at the head if it does insert a small screwdriver into the hole and twist the head counterclockwise hope i helped
5 Related Answers
Anonymous
  • 163 Answers
  • Posted on Nov 29, 2008
SOURCE: Ryobi TP30 straight shaft line trimmer convertible - drive shaft disconnected from motor
check both ends of shaft, they're usually a hex or torx head. sometimes the can strip or even snap off. if you find noticable damage replace the shaft
Anonymous
  • Posted on Apr 21, 2009
SOURCE: My TB475ss starts and dies right away
carb is out of adjustment or gummed up
Anonymous
  • 32 Answers
  • Posted on Jun 12, 2009
SOURCE: pull cord won't rewind
the shaft isnt attached right.
Anonymous
  • Posted on Jul 02, 2009
SOURCE: can not remove spool to replace string
If it's like my Ryobi, the alignment arrows are for feeding in string, not removing the spool. When aligned with the arrows, you should be able to insert two pieces of line into opposite sides of the housing. The ends of the line will come out of the spool next to a tiny hole. Put the end of each of the two lines into the holes, then pull the two lines from the outside. This will lock the ends of the line into the tiny holes in the housing. Now you can turn the housing by hand to wind the lines onto the spool. I think it will take about ten feet of line (on each side).
Alternatively, spin the bump stop out of the assembly. This holds the spool in, so when the bump stop is removed, the spool comes right out.
I hope this helps.
Anonymous
  • 124 Answers
  • Posted on Sep 14, 2009
SOURCE: Bought a Ryobi weed trimmer CS26 from Home Depot.
just cheap equipment. Mark it up to experience and do not purchase equipment fro home center or box stores ever again.
This is just one of the many problems of dealing with
the box stores rather than a full service qualified dealer. If you can
find one in your area, patronize them. Not just when the box store
lets you down but for everything. These type dealers are
disappearing and are not being replaced and soon they will all be
gone.
How do I get the old line trimmer spool off of my Ryobi 18 volt cordless trimer
When looking at the head, you will see to two gray rectangle pieces. Press them both at the same time between your thumb and forefinger and then pull. It should come unlatched and reveal the line spool on the inside
2answers
Ryobi problems
Be sure the spring is not bound up with grass or mud. It has to recoil to push the head down so the line doesn't continue to shoot out.
Automatic line advance not advancing on Ryobi 18v trimmer
I have a Ryobi Model RY28040 straight shaft line trimmer. In my case I replaced the complete String Head Assembly that includes the String Head Housing, Spring, and Spool and the string still did not advance. I then discovered that the bolt in the Spool Retainer cap (the red cap that attaches the spool to the shaft) was fused and not moving. The bolt needs to be loose inside the cap in order to allow the spool to move in and out by the spring. I loosened the bolt and fastened the spool back onto the shaft. Fired it up and bumped it a few times and the line began to advance. Turns out I probably only needed to replace the Spool Retainer rather than the String Head Assembly.
Replacing the spool of string for my black and decker 12v electric trimer ? grasshog model
If it is the same as my old 12V version, flip it over and look at the bottom, this is the cap for the string, on the sides there are two push button latches, depress and pull the cap off. Then reach in and remove the old spool. Insert the new spool with the circular sawtooth design to the inside and push the end of the string through the hole in the side. Replace cap ensuring that both latches engage.
Ryobi 26cc gas trimmer. Can't replace line. Used 1 8'' line thru slots in spool. (3'' each side). Don't understand next step. Push down spool and twist? Should spool stay level...
You line up the head with "arrows" by turning the plastic bump knob on extreme bottom. When arrows line up with the head then you insert your line through the slots "OR" you insert the line in one side and it comes out the other side. Then you have to push pressure DOWN ******* the bump head while twisting the bump head clockwise to "pull in" the string until there's only about six inches left remaining on the "shortest" piece hanging out the side. use scissors to make the lines equal in size before staring the trimmer. Hope this helps.
I was given a used 31cc trimmer but can't get the spool off to replace it. how do i do this?
A typical trimmer has a small bump knob, an inner spool with the plastic string wound on it and the housing for that which is the string head.To remove the small bump knob, hold string head firmly and turn the bump knob counterclockwise. To remove the head entirely, first remove the bump knob. Next, remove the inner spool with string. What should be left is the spring with the end of the gear shaft showing. Some heads are locked on and some just slip over the end of the shaft. Check the gear drive just above the string head for any holes in the collar. An object can be placed in one of the holes to lock the drive and twist the head off.Ryobi's use retaining clips on the shaft which have to be removed.
May 06, 2011 • Garden
How to replace trimer line
Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position. Put cap on and GO CRAZY!
Jim
2helpful
Can not remove spool to replace string
I hope this helps.
Describe string replacement on ryobi trimer
Wind the string on in a clockwise direction.
If it is a duel line then: Cut two separate pieces of string, about 7 ft. each.
Jim
2helpful
How to feed line into a black and decker trimer/edger model st6000 electric?
The ST6000 uses centrifugal force. Once you mount the new spool of string and thread it out of the feeder and into the housing below, plug it in, give it power and hold the line feed button down, feeding the line. Within seconds, the line will feed out through the head and you'll be in business.
Top Homelite Garden Experts
Jay Finke
Jay Finke
Thomas Perkins
Thomas Perkins
Sean Wright
Sean Wright
Are you a Homelite Garden Expert? Answer questions, earn points and help others
