CIPHERLAB 1166 Bluetooth Barcode Scanner  PN S1166RS1N1001 Handheld Barcode Scanner Logo
Question about CIPHERLAB 1166 Bluetooth Barcode Scanner PN S1166RS1N1001 Handheld Barcode Scanner
My scanner is not connecting with my computer program. I have used this same scanner for about 5 years. It reads the bar code and even makes the beep that it has been read but doesn't feed the bar code into the system. The light on top is flashing a short blue beep and a long red beep.
Posted by sc_bowers on
tip
How do I read Barcodes in Microsoft Excel?
<p>Bar code symbols are composed of a number of adjacent bars and spaces of different widths of pre-defined codes. A barcode scanner is used to read or scan the bar code symbol to represent the information to decode. Once the symbol is scanned by a handheld reading device or another, can then be used by computer software to track inventory and perform other functions. Microsoft Excel is a computer application that use bar code information can make the business perform. <br /> <p><br /> <p>1. Insert bar code scanner to your computer using the "interface cable keyboard wedge". The keyboard wedge interface cable looks like the printer port of your computer, and differs only in that a connection between the scanner bar code and serial number of your computer or USB port. The cable is provided as a peripheral pattern with hand-held bar code scanners. <br /> <p><br /> <p>2. Open Microsoft Excel on your computer after the bar code scanner connected to your computer. <br /> <p><br /> <p>3. Links on the Excel cell to the bar code to enter and bar code scanning to load it into Microsoft Excel. <br /> <p><br /> <p>4. View the data in Excel file is translated into a vision of the bar code information. <br />
on Jun 26, 2011 • Computers & Internet
tip
How do I troubleshoot a Symbol Barcode Scanner?
<p>Barcode Scanners Symbol read and translates the barcodes on merchandise. The scanner translates the bar code symbols on the label says the price of the item and merchandising information. Traders use the symbol bar code scanner to identify their merchandise. A programming error in reader bar code symbol will cause confusion and may lead to loss of money. Troubleshooting barcode scanner symbol allows you to identify bugs and find solutions to errors. <br /> <p><br /> <p>1. Remove the installed fonts from the reader bar code symbol. The sources of such capacity to disrupt the functioning of your bar code scanner. Press the "Menu" button on the scanner bed and press the "Select" option when the source is highlighted. Press the Delete button to remove the sources of the sample. <br /> <p><br /> <p>2. Close the bar code scanner Symbol with a source of energy. The scanner has a power cord can plug into an outlet. If the scanner runs on batteries, the battery is fully charged before using the scanner. <br /> <p><br /> <p>3. Move the scanner closer to the bar. The symbol bar code scanner cannot calibrate the bar if you wrong position. Place the scanner directly over the bar and wait for the scanner to read and transmit the code. <br /> <p><br /> <p>4. Wait until the bar code scanner symbol to complete the boot. The symbol bar code scanner is initialized when the USB cable is connected to the computer. Initialization requires a short period of time to complete the process. Let the bar code scanner symbol to be idle for 4-5 seconds before you first scan an object. <br />
2answers
After scanning a bar code I need it to enter and go to next row in excel
This can be possible, therefore it is not an Excel setting. You would need
to use the software that comes with your bar-code reader to configure this.
Try looking in your bar-code reader documentation for "Append Enter" or
"Append Carriage Return"
I'm using Symbol LS1004 with SirsiDynix Symphony 3.3.1 Workflows. How can I tab over after each scan, without having to hit &lt;Enter&gt;? Thanks, -john
Here is what I did to fix the problem of the bar-code scanner not going to next line after a successful scan. (Symbol ls4000i,This fix should work for other models as well)
1. Get the manual for your scanner or here is a link to the Symbol LS400i
https://docs.symbol.com/manuals/3789802a.pdf
You will want to print off few pages that have the proper bar-codes for programming.
2. I usually start with setting scanner to the Default Parameter, this should be in section 5-7,page 50 of the manual.PRINT IT
Warning! If you set scanner to default, you need to be aware of which bar-code types you use. (We use UPC-A) Also if you have it programed for other things already you may not want to set all settings to default. You can skip to step 4. If you do not wish to reset all values to default.
Now scan the Default bar-code.
3. Now program scanner to Enable your bar-code type. (For us Enable UPC-A bar-code is in section 5-22,page 66. PRINT IT
Now Scan the Enable (your bar-code type UPC-A, UPC-E,etc etc)
4.Next You need to set a Suffix Value. The scan Suffix bar-code is found in section 5-80, page 124. PRINT IT
Now Scan the Scan Suffix bar-code
This prepares the scanner for the code of the whatever Suffix you want to add.
5. The Suffix you want to add to fix this particular problem is ENTER. So that it goes to the next line. There is a prefix/suffix value chart on page 162 table A-4. The code for ENTER Is 7013. In order to enter this code you will need to print off the Numeric Bar Codes found in section 5-109,5-110,pages 153,154. PRINT IT
Now scan in 7013 one number at a time to program ENTER as the suffix.
6.Now you have to program the Scan Data Transmission Format found in section 5-81,5-82, pages 125,126 . PRINT IT
(This lets the scanner know to transmit the Suffix after the data.)
First scan the Scan Options Bar-code.
Second scan the <DATA><SUFFIX> bar-code.
Last scan the ENTER Bar-Code.
YOUR DONE !
Your scanner should be working now. Also look through the manual there are some nice functions that can be turned on and off with a simple bar code scan. Such as volume and tone of beep etc etc.
Hope this helps
Nate N7w7
4helpful
We are using a Metrologic MS9520 (keyboard wedge) with QuickBooks. It won't scan barcodes provided by Quickbooks, even though it's supposed to be compatible. We've downloaded about every driver, config,...
What I would first is to bring the barcode scanner back to factory defaults. To do this you will need the manual that came with the scanner, on the first page is a bar code that say "enter/exit configuration mode" scan that first and you will hear three beeps, then scan the bar code for "recall defaults" and rescan the bar code to "enter/exit configuration mode" then retry using your scanner, if this does not work bring up "notepad" on your computer and try to scan any bar code form any retail item. This should scan, if it does net then it could be a defective scanner. See page 2 on the manual link
http://www.posguys.com/download/voyagerprogramming.pdf
1helpful
Symbol LS 9100 does not transmit data
after scanning the defaults barcode you just scan the "Enable LS 9100 Communication" on this manual on the link above.https://docs.symbol.com/manuals/1536503c.pdf
1helpful
2answers
Hi, i am trying to configure my barcode scanner LS2208 to put a {TAB} in when scanning
There should have been a sheet or book of bar codes that came with your scanner. These codes will allow you to program your scanner to do most anything, including adding a tab. You simply look at the bar codes and read what they do. you simply scan the one that adds a tab and it will forever add the tab unless you re program it.
If you have lost your book/bar code page, you should be able to go to the manufacturer website and download/print a document with the programmable bar codes.
How to send information from computer to scanner WWS800 / USB
bar code scanner.
well you need to install the makers software to use that
and the tool came in USB version and Bluetooth.
both need software and later needs Bluetooth working on PC.
The Bluetooth ports are optional on many PCs for sure desktops
NO PC stated by you nor OS running on it.
why not ask the maker for help,
they will ask the same silly questions, like what exact model of scanner, number model, and what OS device , windows? android ,?
https://www.waspbarcode.com/barcode-scanners
Hooked scanner up to new computer. Reads bar code
It sounds like you are connecting to a serial port and you are trying to scan into a program that needs keyboard data. Download the "Softwedge" program from the Metrologic website.
Top CIPHERLAB Computers & Internet Experts
Tom Chichester
Brett Duxbury
Brett Duxbury
Larry Ng
Larry Ng
Are you a CIPHERLAB Computer and Internet Expert? Answer questions, earn points and help others
