Question about Logitech X-530 Computer Speakers
Only have the sub itself, Can I still use it and if so how?
Posted by mistereddy22 on
Anonymous
    New Friend:
Unfortunately you will not be able to use the sub-woofer by itself because the input for the Logitech X-530 has a special cable to connect to the sub-woofer. You could always try looking on eBay or Craigslist for replacement parts.
Posted on Aug 18, 2011
Loud noise coming from subs car audio
All of the vibration from the subs rattled something loose, Most likely is the speaker to enclosure fasteners but it could be the case itself, internal baffles or even the speaker frame itself is coming apart.
Sub-Zero 650 - Keeps turning itself off. The
HI,
Are you having any fault codes along with this issue? Does the fans and light stop working also? This is unusual, is this the G or O model? I need more information to assist you.
Please let me know.
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
1helpful
What does the sw level setting do?
hello.. the sw level is short for your subwoofers volume setting .when you use a subwoofer thats powered and connect it to your recievers sub out,this is than a way to adjust the subs volume from your seating position rather than only adjusting it from the back of the sub.. i recommend putting your subs volume(on the back of the sub itself) to midpoint and playing a bass heavy song or movie and adjusting the sub level on the reciever to how you like it.. enjoy
The dvd player and surround speakers are playing but the subwoofer is playing some radio station
youve got the sub plugged to the sub-out on the receiver as well as have set a crossover-point on the sub itself. this is how you can tune in a station. re-plug the sub to any audio out on the back of receiver.
2helpful
I have the klipsch sub-10 subwoofer, making noise after use
it sounds like the sub is rubbing in the voice coil.
put the speaker in upside down to what it was before.
sometimes that extra bit of downward pull is enough to offset the error.
There are speaker reconing experts out there but it is cheaper to replace the sub itself.
the sub can be replaced for sure.
2helpful
2answers
MTX 12'' sub noise
Sounds like your sub is overextending itself, and possibly losing contact at the voice coil. Overextending will make a weird rattling sound, losing contact at the voice coil will make a popping sound.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
1helpful
Can i hook up a powered 12'sub to a Pheonix Gold xs2500 amp without blowing the speaker
First I hope you remove the speaker wires from the speaker that come from the built in amplifire. You cannot hook the powered sub to the amp without doing that first. Then all you need to do is run speaker wire from the sub out of the box to the amp. In no way can you hook up any other part of the powered sub, but the sub itself, to the amp. If you know the wattage of the sub and the ohms then wire it to the amp correctly. Your phoenix amp will put out 125 watts x 2 at 4 ohms and 250 watts x 2 at 2 ohms and 500 watts x 1 at 4 ohms bridged. Remember, only the sub itself in the sub enclosure can be connected to the amp. Hope this helped you. Let me know if you need more help.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/mark_b53a7494531bf96d
Kenwood vr405
Yes you can! I have the 405 as well. Using a RCA-style cable, simply connect your powered sub to the sub pre out on the back. If its turning off when you connect it and receiver has been working fine otherwise, troubleshoot. Either the sub preout (the 405 itself), the cable or the sub must be the culprit. 1st try a different cable, they do go bad. If problem persists, test the sub with another receiver or take back to store and have them test it. After that, the only thing left in the equation is the receiver itself. I've had mine for 15 years and lets face it, we've got our money's worth. A bad receiver is the best excuse to upgrade!
2answers
Subwoofer shutdown
I'm having the same issue as pdoug: Sub rumbles in test mode, doesn't produce sound otherwise. Which makes me suspect it's the receiver itself -- the filter (or whatever) it is that should be separating the bass signal and sending it to the sub is not working. At least that's my guess.
Either way... this sucks.
Logitech X-530 Computer Speakers Logo
Top Logitech Audio Players & Recorders Experts
Ekse
 Francisco Mauricio...
Mandeep  Singh
Mandeep Singh
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
