If your chest freezer is showing signs of age, it may begin leaking. There are a few methods for troubleshooting faulty chest freezers but knowing some of the obvious signs of why it might leak can be very useful if you need to fix it yourself. Leaking is not limited to older models so be aware that certain maintenance procedures can help prevent leaks in newer models.
Understanding Changeable Parts Prior to Troubleshooting
There are not that many serviceable or changeable parts inside a chest freezer. A chest freezer works on a very simple basis. It contains evaporator coils, condenser coils, a compressor, a compressor overload, a relay and a thermostat. These are the basic moving parts of a chest freezer but some of them are not serviceable.
The condenser coils condense the water and the evaporator coils disperse excess water caused by the freezing process. The compressor is a heating component which compresses excess water and recycles it through the system.
Defrosting
Remove the contents of your chest freezer and place them in an alternative area to keep them frozen. Unplug and defrost your chest freezer before you do any troubleshooting or maintenance. Wipe and clean the inside of the freezer so that when you plug it back in it, will free of any grime or loose bits of debris. A clean freezer will also help to promote visibility when it comes to fixing leaks.
Where is the Leak?
Once you have defrosted your freezer, you need to establish which part of the freezer the leak is coming from. It could be coming from the inside of the freezer and this would indicate a thermostat issue. Alternatively, it could be coming from the freezing unit at the back of the freezer. Water always finds a way to escape so your leak could be restricted to one place but the actual cause could be elsewhere. Locate the drain tube which is normally found at the back of the freezer. You will probably have to unscrew or unclip the backing panel.
Check the Drain Hole
If the drain hole on your chest freezer has become blocked for any reason, you will need to clear it thoroughly to continue getting the best performance from your chest freezer. The drain hole is a component within the lower works of the freezer through which excess water runs to be recycled.
Compressor Issues
Your chest freezer contains a compressor which evaporates the excess water from the freezer. The freezer will defrost excess ice and the water flows down the drain tube to a pan where the heat of the compressor evaporates the water. If your compressor has failed, the leak will be caused by the water failing to evaporate. Have a repair contractor replace your compressor or, if this is not cost-effective, you may need to buy a new freezer.
Thermostat
If your freezer is not freezing at all and is dispersing water in several places, you may well have a thermostat failure. Check that your freezer is cycling correctly prior to making changes or altering the thermostat. Only if the freezer is not cycling are you likely to need to change the thermostat. If you have checked all the parts of your freezer and you still cannot locate the leak, calling in a service technician might be the best answer.
Hoping this will help to solve the problem....
Defrosting
Where is the Leak?
Compressor Issues
Thermostat
I hope this will helpout.....
SOURCE: water leak
I am having the same problem. I do have a light layer of ice at the bootm of the freezer.
SOURCE: Water dispenser leaks of my whirlpool refrigerator gs6shaxk b01
on the bottom of the faceplate there should be two small pry spots to remove faceplate. once the faceplate is removed you should have acess to the inside.
SOURCE: LEAKING WATER DISPENSER, CAN'T GAIN ACCESS
you have to get way down low and look up under the rim of the splash plate and you'll see two flat openings where you can insert a screw driver. There ya go... Good luck
SOURCE: water is leaking onto the inside floor of the
You have a leaking water tank inside the refrig behind the crispers . The tank ( now plastic hoses ) is easily replaceable . Called a water resevoir technically .
SOURCE: Water dispenser on refrigerator leaks inside the refrigerator
Check filter houseing and filter, Its either not installed correctly , has a line leaking or disconnected to filter or has frozen over the filter. Good Luck.. Hope your freezer is keeping cool enough.. AARS
You could have a clog in the housing underneath the dispenser where the water flows through a hose into the tub. Pull the dispenser drawer completely out. There is a tab that needs to be depressed to release the drawer and remove it. Check the opening at the bottom of the housing just inside the dispenser housing opening to see if a small sock or garment is clogging this opening. Reach down into this opening to see if an item is inside the hose. This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Replace the dispenser drawer and try the washer again. If the dispenser still leaks, then I recommend calling a service technician to diagnose and fix this problem.
